Electronic malfunction
08.05.2020 20:41 # 1
Mustafax07
Mrb 2003 307 my car was not working bsi brain was fixed, the problem was fixed but now it is going cold in the morning the headlights are on, the wipers are working, the screen is going and going, the car is running 2, it goes crazy after 3 minutes, it is recovering, the last airbag is malfunctioning on off, it turns out when I turn it off, it does not cause any problems during the day, no malfunction except in the morning, no malfunction except in the morning does not give
08.05.2020 20:41 # 2
206pt
Hodja, if there is a bosch car service at your location, take it there.
08.05.2020 20:41 # 3
onlycihan
Some vehicles have a test mode, the indicators end to zero and all the lamps are flashing or are also called service mode.
08.05.2020 20:41 # 4
Mustafax07
Bsi started after his brain was made, I ask the electrician, he says there is a chassis but he does it when the weather is cold, he does not do it above 10 degrees.
08.05.2020 20:41 # 5
samet206
If the incident was a coincidence with the brain repair, this should not be a separate issue, but it is not the only thing you say, and all of them are electronic failures. The interesting thing is that it occurs after the brain repair.
08.05.2020 20:41 # 6
ggitaristt
I will say something brother ..
In a cold weather, if you can hold it on your brain, hold a hair dryer or something .. Warm it up a bit .. then run a thousand.
08.05.2020 20:41 # 7
Mustafax07
There was zero battery on it, the brainman said from the battery, he measured the battery, he said nothing, but I changed it anyway, but it was futile but I would try the blow dryer idea thank you for your valuable comments
08.05.2020 20:41 # 8
Beyinci_Ugur
Bsi has never been done just cleaned with thinner or there is an error that is overlooked, but the problem is 100% bsi electronic hardware failure change best solution repair good master keeps difficult external seam
08.05.2020 20:41 # 9
Beyinci_Ugur
It can be misleading or if there is a layer failure on the board, it is corrected not by heat but by shaking. I think it confuses.
08.05.2020 20:41 # 10
Mustafax07
They said there was no zero, they said 750 TL and it was a model with a cover.
08.05.2020 20:41 # 11
[QUOTE = Mustafax07] They said there was no zero, they said 750 TL, and it was a capped model [/ QUOTE]
if you want to call my teacher and have a view. They tell you whether your vehicle is suitable according to the chassis number.
