Electronic malfunction 307cc
08.05.2020 20:47 # 1
Bilal307cc
All the lights on the instrument panel of my vehicle are on and the wipers are self-powered, the headlights turn on by themselves, and I cannot control the vehicle, so the horn does not sound, the signal does not come down, the windows do not come down, I cannot stop the wiper, I cannot turn off the headlights, what is the reason for this?
08.05.2020 20:47 # 2
ggitaristt
When I burned the tape's fuse, it was the same for my car, the only difference was that all the indicator lights were not on. There was only one exclamation mark. Check all the fuses .
However, there is a possibility that the car may be in service mode. Disconnect the battery terminal and reconnect it after a few minutes.
If this problem persists when you switch on the ignition, you may need to re-program the car in service or a new brain.
Prepare for the worst chance pray for the best I think ..
08.05.2020 20:47 # 3
First of all, welcome to us. in addition to what our friend wrote
1-battery may be dead.
The 2-headlamp signal arm may be malfunctioning.
There may be a problem with the assembly error when making electrical additions such as the audio system and exnon made to the 3-vehicle later.
4-bsi water may have come into the fuse box, which may cause oxidation and electronic malfunctions.
5-tool absolutely connect the pc and have a look at the fault codes.
08.05.2020 20:47 # 4
Bilal307cc
After removing and attaching the terminal of the battery, it gets better, sometimes it doesn't do for a long time, sometimes it repeats immediately.
08.05.2020 20:47 # 5
sagopakajmer1903
[QUOTE = Bilal307cc] After the battery is removed and plugged in, it improves, sometimes it does not work for a long time, sometimes it repeats immediately [/ QUOTE]
teacher, did you solve the problem? you Paylaşabilirmis
