electrical problem 406
Homepage » PEUGEOT MODELS (FAULTS AND SOLUTIONS) » 406
08.05.2020 19:40 # 1
406
Hello. I ask for help on a subject. There is a lack of malfunctioning lights in my car, which has started to be intermittently lately, and within 2 minutes the stop, abs, airbag, handbrake and bikac malfunction light are on, the vehicle is working properly but the electricity is working properly. It does not work, only the tape does not work, and the road computer does not show miles.
08.05.2020 19:40 # 2
First of all, welcome problem. I would recommend you to have two or more battery related power generators.
08.05.2020 19:40 # 3
406
Thank you. Thank you. In the past, my mars motor was completely repaired, the intermediate battery and charge dynamo values were normal. Then there was a problem.
08.05.2020 19:40 # 4
koray.turan
Sounds like it's not about the brain first, have your battery checked first
08.05.2020 19:40 # 5
vpro
All the lights are usually inadequate or over-powered.
08.05.2020 19:40 # 6
Yes, even if there is no problem in control, there may be such problems when there is a voltage increase in my opinion. I think the voltage should be measured and checked while the vehicle is running.
08.05.2020 19:40 # 7
406
I will show you the charge to another point, thank you very much
08.05.2020 19:40 # 8
koray.turan
I hope your problem is solved
08.05.2020 19:40 # 9
406
Unfortunately, the bsi was out of the brain and we could not find the piece.
08.05.2020 19:40 # 10
406
In such a delightful vehicle, these problems are cooling down from the vehicle.
08.05.2020 19:40 # 11
[QUOTE = 406] In such a delightful vehicle, these problems are cooling off the vehicle.
Good luck my teacher, the sound system installed later in the vehicle can cause such problems in xenon headlights.
