electrical problem |
| • Homepage » PEUGEOT MODELS (FAULTS AND SOLUTIONS) » All Questions About Your Vehicle | |
| 08.05.2020 16:33 | # 1 |
erkerd5429 |
friends I wanted to refer to your opinion about an electrical problem |
| 08.05.2020 16:33 | # 2 |
How about the battery? |
| 08.05.2020 16:33 | # 3 |
erkerd5429 |
3 months since I bought the car, I never looked at it, I can't look at it until Saturday, I don't have any opportunity. I wanted to know if there was any other problem.
| 08.05.2020 16:33 | # 4 |
Try the same process with the headlights on, turn on the headlights and start the starter, if the lights get too weak, it is time to change the battery. > Reviews
| 08.05.2020 16:33 | # 5 |
It is the battery. |
| 08.05.2020 16:33 | # 6 |
erkerd5429 |
If I think that, the headlights were left on once, the charge was completely finished, we did some reinforcement or something, but the battery will have to go up to here. |
| 08.05.2020 16:33 | # 7 |
[QUOTE = erkerd5429] I think the headlights remained on once it was completely over, the charge was finished, we did some reinforcement or something, but we had to get the battery up to here, it was obliged to go 160 paper [/ QUOTE] 110 lira happy battery here. you give the old battery.
| 08.05.2020 16:33 | # 8 |
I wrote about the price to be deceived. |
| 08.05.2020 16:33 | # 9 |
[QUOTE = erkerd5429] if I thought that the headlights remained turned on completely, the charge was finished, we did some reinforcement or something, but we had to get the battery up to here, it was obliged to go 160 paper [/ QUOTE] saving mode should be activated. When the headlights are on. Interresan.
| 08.05.2020 16:33 | # 10 |
erkerd5429 |
[QUOTE = yavuz25] I know that the price is deceived. to friend last month we bought 72 amp birmot (fiat orj.akü) I think 72 amps would be a problem
| 08.05.2020 16:33 | # 11 |
[QUOTE = erkerd5429] [QUOTE = yavuz25] I wrote about the price to be deceived. [/ QUOTE] why do you think high amp battery? border = "0" alt = "Ermm" title = "Ermm" />
| 08.05.2020 16:33 | # 12 |
Install the original whatever it is. High battery is not very good, contrary to what is spoken among the public. |
| 08.05.2020 16:33 | # 13 |
erkerd5429 |
[QUOTE = yavuz25] [QUOTE = erkerd5429] , if I thought that the headlights remained on completely, the charge was finished, we did some reinforcement or something, but we had to get the battery up to here, obliged to go into the 160 mode [/ QUOTE] saving mode was activated How to run the battery when the headlamps are on.Enteresan. [/ QUOTE] & nbsp ; I did not understand too, while listening to the tape switched to saving mode, the tape was closed a few times & nbsp; headlights are not covered, I turn it off with a warning, normally the lady is using the car she got it
| 08.05.2020 16:33 | # 14 |
erkerd5429 |
Orj 60 amps, I think let's do it, if you say it would be harmful, they usually say that a high amp is better for a tube car.
| 08.05.2020 16:33 | # 15 |
[QUOTE = erkerd5429] [QUOTE = yavuz25] [QUOTE = erkerd5429] [/ QUOTE ] I think the headlights remained on all the time, they were completely discharged, we did some reinforcement or something, but the battery had to go up until it had to go 160 paper [/ QUOTE] < div> saving mode should be activated how the battery can run out when the headlights are on.Enteresan. & nbsp; I did not understand too, while listening to the tape switched to saving mode, the tape turned off a few times & nbsp; headlights are not covered, I turn off with the warning normally the lady is using the car, she has the car. Did you get the car 0? 2.el?
| 08.05.2020 16:33 | # 16 |
[QUOTE = erkerd5429] Orj 60 amps, I think we should do it, if you say it would be harmful, they usually say high amps would be better for the tube car [/ QUOTE] I do not mind. A master in the industry (he thinks he is a master, whatever) pevgeot buying is not comfortable cars, you do not want to drive, did not creak. No pejo was not kept, and so on. But I did not listen and we preferred the pejo. "smileys / smiley2.gif" border = "0" alt = "Wink" title = "Wink" /> Install whatever is the original. Do not risk your car or yourself. /smiley2.gif "border =" 0 "alt =" Wink "title =" Wink "/>
| 08.05.2020 16:33 | # 17 |
erkerd5429 |
vehicle 2, hand bought 3 months ago |
| 08.05.2020 16:33 | # 18 |
[QUOTE = erkerd5429] orj 60 amps, I think let's do it, if you say the damage will usually be higher amps to the tube car they say [/ QUOTE] div > I would like to talk to those who said this, I was wondering what it actually says based on.
| 08.05.2020 16:33 | # 19 |
[QUOTE = erkerd5429] vehicle 2, the hand was bought 3 months ago [/ QUOTE] except for the parking lamps, the electricity of the entire system must be cut in saving mode. They may have played with this system for another purpose. .
| 08.05.2020 16:33 | # 20 |
By the way, God bless you.
