Electrical leakage
08.05.2020 16:19 # 1
muntehaozen
Everyone,
After my car got out of sleep (i.e. 3 minutes after the stop), the car still seems to be 0.32 Amps leak. There was still the same leak that did not happen. No fuse was found in the fuse to find out where he tried by removing the fuses one by one. But the current constantly attracts a 0.32 Amp in the vehicle. He said that he could find it when he went to the service and when the pc was connected, he left me, he said, and it became clear that there was no problem with the sound system.
I wonder:
What about the cost of this in the service?
And all the connections in the audio system are canceled & nbsp; but does the service say that the service originates from this and tries to chip me out :) :) divid
& nbsp; div> Vehicle 2004 model 307 xt tube.
Regards,
& nbsp;
& nbsp;
08.05.2020 16:19 # 2
tazmaniac
For a 320 mA car, it can be considered as a stationary current, in fact, such a current does not discharge the battery. What was your complete complaint?
08.05.2020 16:19 # 3
muntehaozen
[QUOTE = tazmaniac] For a 320 mA car, it can be considered a stationary current, in fact, such a current does not discharge the battery. He finished the zero battery completely within -3 months. And because of my job, I only do 1 km a day for 20 days of the month, the distance from the room to the subway from the house. Is it normal to have this current in all 307s. Why is the battery running out every 3 months?
08.05.2020 16:19 # 4
badcombatant
BSI, that is, it will be obvious that the control of the brain in the corner under the left side of the steering wheel can be removed from the master, and water may have come from the socket feet, and if it has water or moisture, it can send leakage current to the vehicle through the electronic card. check it, solders may be cracked or broken, may need to renew them, hopefully you will solve the problem in a short time & nbsp;
My vehicle is sending current to the screen of the front chest and running it according to the head & nbsp; "
08.05.2020 16:19 # 5
If your friend has an external alarm system connected to your car, the room may be finishing. Apart from this, the torpedo light and the trunk lamp can be checked and the button is faulty and it may be constantly working. Let it be easy.
08.05.2020 16:19 # 6
without forgetting, take a look at the 12V outputs of the vehicle, the cigarette lighter sockets, maybe there is a device you plug in and forget (such as transmitter, charger etc.)
08.05.2020 16:19 # 7
muntehaozen
UPDATE
08.05.2020 16:19 # 8
bestfear
SLM ... My 307 sw also caused such a problem last April ... The battery was exhausted ... while buying the new battery, the battery sent it to the electrician, stating that it might be leaking in the vehicle ... They suspected the tape with an original TV, we even made a key to the tape, but the leak The situation that seemed to continue ... after a few electricians, the last electrician said that there was no problem, that Bs and the central lock seemed to leak since the circuit was activated ... no problem for now ...
08.05.2020 16:19 # 9
muntehaozen
Continuously resetting the battery at 0.32 Amperes in 3 months is a serious result. This is the case with all models. I will let you know the result.
08.05.2020 16:19 # 10
badcombatant
I hope nothing will happen in BSI & nbsp;
We look forward to sharing the result
08.05.2020 16:19 # 11
tazmaniac
[QUOTE = muntehaozen] [QUOTE = tazmaniac] For a 320 mA car, it can be considered as a stationary current, in fact, such a current does not discharge the battery. What was your complete complaint, so after a while does the vehicle not work [/ QUOTE]
Yes, I finished zero battery completely in 2-3 months. And because of my job, I only do 1 km a day for 20 days of the month, go to the metro from the room to the house. Is it normal to have this current in all 307s. Why is the battery running out in every 3 months? that?
This current is normal for all 307s, or for this vehicle, the current is normal. but it's not like that. you don't just give it time to recharge the battery, i'm strange what you do "laugh" especially 1 km a day shouldn't finish As you wrote, on the contrary, such short distances reduce the life of the battery, 1 km of the road is what you are going to drive, and it is healthy.) joke, the battery will not be charged as you use it.I will tell you if there is a leak before the next day or something but There was no such problem. I had a problem like that, but the car was not working the next day. The original tape had a CD mechanic. The tape was on the stand. Isn't it separate?
08.05.2020 16:19 # 12
muntehaozen
While the entire sound system including the Bgün tape was disconnected, the pc was connected, there was no leak in the car. But 0.32 amps still exist :) I went to the electronics shop, sent it to the electrician, went to the electrician, he said from the sound system, but there is nothing related to the system. I am waiting.
08.05.2020 16:19 # 13
[QUOTE = muntehaozen] When the whole sound system including tape recorder was disconnected, the pc was connected. There was no leak in the car. But 0.32 amps still exist :) I went to the electronics shop, sent it to the electrician, I went to the electrician, he said from the sound system, but there is nothing connected with the system. I am looking for a place to solve it. I am waiting for your help. easy come.
08.05.2020 16:19 # 14
muntehaozen
Conclusion:
06ilhan06 I went to a place recommended by our brother. It looked like there is no leakage, it is normal, this is 0.32A leakage current. and the happy battery says normal value up to 0.07 Amps. If there is more than that, it made a clear result saying there is a leak. Now, I was confused in my mind. In 3 months, zero battery ran out, I had to charge the battery 2 times after that. do I need to do?
muntehaozen 2011-11-10 22:17:27
08.05.2020 16:19 # 15
Well, I am amazed now. There is something strange behind this event, but I couldn't understand. wait for the car, so disassembly as soon as you stop.You can disassemble it after waiting. come out in me, heralde.sirf for you, let me go and measure this event.
08.05.2020 16:19 # 16
muntehaozen
Well, I'm waiting for your news tomorrow, brother, I am crazy now .. & nbsp;
08.05.2020 16:19 # 17
emin15
There may be a problem with the alternator, disconnect the charging cable and see if there is a leak.
