Electric Side Mirror
08.05.2020 16:58 # 1
AsMeRiL
Hello friends,
I am considering replacing the manual side mirrors of my 2003 model 1.4 HDI with electrics. Can i do that Do I have problems with electrical connections and control (if I change the glass on / off) buttons? Briefly, is it necessary to pull electrical wiring for this process? Thank you for your answer. Reviews
08.05.2020 16:58 # 2
sezar206
I don't have any handling or anything very important. If you can afford a lot of it, stop trying if the master cannot.
08.05.2020 16:58 # 3
dukenukem82
you pull it in the installation, you wear it in the mirror adjustment button, but you can
08.05.2020 16:58 # 4
muratoner
It would not be difficult to do, but I think the mirror is not worth giving so much money for a feature you will use annually ..
08.05.2020 16:58 # 5
ertugrulll
[QUOTE = muratoner] It would not be difficult to do but I think the mirror is not worth paying so much for a feature you will use annually ..
"Clap" & nbsp; I did everything. Whether the rear windows are automatic, the side mirrors remain electric. But I went to the master, if the car is yours, he said no need. He said that you can set the mirror once a year on the bow, so that the money interfering with the brain of the car, the doors, the internal isolations are torn, there is no need. I suppose you have plenty of money in the back window. there is no need for two operations, pity your money, set with your hand, you will do sports with the words, your mirror and back glass are over.
08.05.2020 16:58 # 6
furkan111
certainly not impossible, but it is worth it to me, but ... I see it very useful especially when it is very comfortable in the parks aside from the side ...
08.05.2020 16:58 # 7
sezar206
Master Banim was confused. I thought I was talking for a moment. The eastern money the man says is probably quite a lot :)
08.05.2020 16:58 # 8
muratoner
08.05.2020 16:58 # 9
volkan22
bro brother boswer you don't waste your mirror work but it is your decision if it is left in you but i think it is costly and unnecessary ...
08.05.2020 16:58 # 10
AsMeRiL
Thank you guys for your comments. Yesterday I removed the plastic part inside the car with the manual mirror arm manually. Let me see what is inside, the socket for the electric mirror is pulled out. :): So, as a result, I will only solve it with the cost of the electric side mirror and the control button. Either my goal is in the reverse gear event. When I shift into reverse, I will try to make the side mirrors point down automatically .. & nbsp;
08.05.2020 16:58 # 11
muratoner
You need me if you do that job, bro ..
08.05.2020 16:58 # 12
volkan206+
If this mirror work is actually happening and the cost is not too cold, I would like why not ...
08.05.2020 16:58 # 13
seyyah
I certainly do. In addition, an automatic mirror is absolutely essential for berthing close to the curb and in some parking lots.
08.05.2020 16:58 # 14
Alicilik
[QUOTE = AsMeRiL] Thanks for your friends comments. Yesterday I removed the plastic part inside the car with the manual mirror arm manually. Let me see what is inside, the socket for the electric mirror is pulled out. :): So, as a result, I will only solve it with the cost of the electric side mirror and the control button. Either my goal is in the reverse gear event. When I shift into reverse, I will try to make the side mirrors point down automatically .. & nbsp; [/ QUOTE]
Could you take a photo of my teacher? I was very curious how was that installation
08.05.2020 16:58 # 15
spearo
o cables for tweeters and heat sensors;)
08.05.2020 16:58 # 16
Alicilik
[QUOTE = spearo] those cables for the tweeter and temperature sensor;) [/ QUOTE]
I fell into space when there wasn't a cruise cruise "Big
I bought the last leather steering wheel, but sometimes when I turn the steering wheel, there is a noise between the com2000 and the steering wheel.
When I disassembled it, I looked at the steering adjustment and they tightened the bolts in the middle. I'll look at a vehicle that is a plot.
Finally, I find the line to the ceiling lamp in a handheld bsi. I say that I will make lighting to the stand and I will not pull it from the ceiling. "LOL"
08.05.2020 16:58 # 17
spearo
[QUOTE = Receiving] [QUOTE = spearo] those cables for tweeter and temperature sensor;) [/ QUOTE]
I fell into space when Abi cruise was not there
I bought the last leather steering wheel, but sometimes when turning the steering wheel, there is a sound between com2000 and the steering wheel, I couldn't figure out what was causing it.
ali topically open the answers to the questions we put them there I even found it;)
08.05.2020 16:58 # 18
Bugra
Could you say the side mirrors but the friend who opened the subject has not been active for a long time. Although most friends do not need it, the current manual mirrors are not automatic during washing and wiping, so the setting of the mirror glass changes. but if it were electric it would be constantly fixed. Every time I wash and wipe my car, I try to make adjustments.
As the friend says, there are sockets in the twists. Will it work?
08.05.2020 16:58 # 19
qqyyxx
http://www.sahibinden.com/ilan/yedek-parca-aksesuar-donanim-tuning-yedek-parca-otomobil-arazi-araci-elirdekikli-ayna-106494606/detay/ I bought this ad to apply to my own vehicle but I did not have the opportunity to apply it because I put my car on sale. you do not have any work with the brain of the car, you just connect the related cables through the door & nbsp; to the control (where it will be marked) then you start by using plus and minus electricity. & nbsp; when it comes to mirrors. no need to buy a mirror, you open the mirror and install these electric motors instead of the manual motor & nbsp; process is ok. Someone with a prone time can easily do it. If anyone wants, I can help.
08.05.2020 16:58 # 20
Bugra
I cannot see the link because I am at the workplace, but as you say, the master will mount it in place of the manual engine and it is hard to find in our country.
Page : / 2
