Electric leakage battery fiss
08.05.2020 15:10 # 1
bestfear
Back to school today, the battery did not print the battery ... We had to force it to run ... I pulled the battery on the battery, it was happier for 1.5 years, the control was said to have a leak in the vehicle ... I went to the electrician and checked it. He said that it might originate from here ... because the clock was quite late, the industry was shut down and I came home and dismantled it myself ... but the leak still continues ... how can I identify the problem ...
The masters in the industry do not know anything or ask to find their master ... This work will tire me ...
08.05.2020 15:10 # 2
Carmania
First of all, get past .. I think your tape is connected to the contact and ask to be tested to bidet die. I guess your tape is not connected to the contact.
08.05.2020 15:10 # 3
If Akun is full and you have a multimeter (they call it an avometer in Turkish) and if you understand these things, connect the multimeter to the battery and see the leap on the screen. Then open the fuse panel and start pulling the fuses one by one. If the value is changing, it means that there is a flap where that insurance is attached. In this way, if you are lucky, you can have a general idea of where the leak is.
08.05.2020 15:10 # 4
bestfear
not connected to the contact ... but I removed the tape completely .. all the cables are properly insulated ... the leak continues ...
08.05.2020 15:10 # 5
bestfear
[QUOTE = koliva] If Akun is full and you have a multimeter (they call it an avometer in Turkish), and if you understand these things, connect the multimeter to the battery and see the leap on the screen. Then open the fuse panel and start pulling the fuses one by one. If the value is changing, it means that there is a flap where that insurance is attached. In this way, if you are lucky, you can have a general idea of where the leak is.
Yes, it came to my mind ... I will apply what you say at the first opportunity ...
Is there a fuse box diagram in the booklet so that I can only understand where the fuse I removed is related to ...
08.05.2020 15:10 # 6
BSI-1
Fuses
Rating
Supply
Application
F1
10A
+BB-1
Rear foglight
F2
15A
+BB-1
Rear wiper
F3
F4
15A
+BB-2
+VAN BOD2 Front electric windows
+VAN BOD2 Sunroof
F5
15A
2100
Brake lights
F7
20A
+AA
Rear roof light
Front roof light, map reading light
Front 12V socket
Cigar lighter
Glove box light
F9
30A
+BB-1
Sunroof, front electric window power
F10
15A
+BB-2
Diagnostic plug
Rear 12V socket
F11
15
+BB-2
Radio RB, RD,RT
Multifunction screen B
CV 00
Automatic transmission
F12
10A
+BB-2
Front right sidelight
Rear right sidelight, number plate light, trailer
Locking, alarm, ESP, hazard pushbutton
AC controlpanel light
Ashrtay light
Seat pushbutton
Automatic transmission pushbutton
F14
30A
+BB-1
Central locking control
Dead locking control
Central unlocking control
F15
30A
+BB-1
Rear electric windows (Version D and E)
Brake lights input
F16
5A
+BB-2
+VAN BOD1 BM34
+VAN BOD1 anti theft alarm
+VAN BOD1 particle filter
+VAN BOD1 CV00
+VAN BOD1 airbag
F17
10A
2100
Right brake light (including third brake light)
F18
10A
+CC
Diagnostic plug
CV00
Brake light, clutch pedal switches
Coolant level switch
Brake switch (backup)
F19
SH
+BB-2
Park shunt
F19A
30A
+CC
Park position
F22
10A
+BB-2
Front left sidelight
Rear left sidelight, number plate light, trailer
F23
15A
+BB-2
Alarm siren
Alarm volumetric control unit
F24
15A
+BB-2
S VAN COMF instrument panel
S VAN COMF radio (+tel)
S VAN COMF display
S VAN COMF air conditioning
S VAN COMF parking aid
F26
30A
+BB30
Heated rear screen
Engine Fuse Module (BM34) Module-1
Fuses
Rating
Supply
Application
MF1
40A
+BB
GMV 100/150 AND 300 Watt
MF2
30A
+BB
ABS/ESP: pump
MF3
30A
+BB
ABS/ESP: solenoid valves
MF4
70A
+BB
BSI power supply +BB-1
MF5
70A
+BB
BSI power supply +BB-2
MF6
20A
+BB
Heated seats (ccs police)
MF7
30A
+BB
Anti-theft power switch
MF8
70A
+BB
Electric power steering. (GEP)
Engine Fuse Module (BM34) Module-2
Fuses
Rating
Supply
Application
F1
10A
+CC
Automatic transmission reverse lights
Automatic transmission starter inhibitor relay
Manual gearbox reverse lights
Vehicle speed sensor (TU3/EW10)
F2
15A
+ BB
Canister solenoid valves (TU/EW)
Fuel pump
F3
10A
+CC
Power steering ECU
ABS or ESP ECU
F4
10A
+CC
Additional heating relay signal.
Injection ECU
Fan motor relay signal
Automatic transmission ECU
Shift lock relay singal
Shift lock motor signal
Automatic transmission push button signal
F5
15A
+ BB
PF ECU
F6
15A
+ BB
Both front foglights
F7
20A
+ BB
Head light washer pump
F8
FREE
F9
15A
+ BB
Left headlight low beam
F10
15A
+ BB
Right headlight low beam
F11
10A
+ BB
Right headlight high beam
F12
10A
+ BB
Left headlight high beam
F13
15A
+ BB
Low and high tone horn
F14
10A
+ BB
Washer pump, front and rear
F15
30A
+ BB
Ignition coil (TU/EW)
Diesel heater (DW10TD)
Diesel injection pump (DV4, DW10)
EGR solenoid valve (EW10)
RR oxygen sensor (TU/EW)
Front oxygen sensor (TU/EW)
ECU 1320 (DW10 Siemens)
Injectors (TU/EW)
Air flow meter (DW, DV4)
Solenoid valve EGR+THR (DW10 TD)
EGR solenoid valve (DW10TD)
Coolant heat solenoid valve (DW1ATED)
Turbo pressure control solenoid vlve (DW10ATED)
F16
30A
+ BB
Air pump
F17
30A
+ BB
Front wiper, slow and fast speed
F18
40A
+ BB
Air conditioning blower motor
08.05.2020 15:10 # 7
Just find your place. Come here, write down your number and the helper will come out. You can also look at the table above.
08.05.2020 15:10 # 8
bestfear
ok ... thank you ... I'll get back to work tomorrow ... I hope I find it ... if I don't find it as if the way to the service will be kept ...
08.05.2020 15:10 # 9
bestfear
I went to the private service today ... they directed it to the electrician in the industry ... the master looked at it ... he said something like the situation that seemed to be illegal, the brain continues to run in the background ... He advised me to replace the battery ... by giving the old battery I bought a 60 amp happy battery (123 TL) By the way, the severity of the leak decreased when I removed the tape ... I will make an extra key to the tape ...
08.05.2020 15:10 # 10
Come on with this.
08.05.2020 15:10 # 11
bestfear
thank you ... hopefully the master says it comes true ...
