electiric circuit faulity error and antipolation h
08.05.2020 19:09 # 1
yemre55
I have 2005 307 1.6 HDI LOOK. I get this warning from time to time in my car and the climate control panel does not work. Does anyone have information? Thanks ... it also gives antipolation error but sometimes it is misleading sometimes it does not.
08.05.2020 19:09 # 2
berk2309
measure the charge of the vehicle and look at your battery, if the charge is high, it is a connector failure.
08.05.2020 19:09 # 3
yemre55
I made the battery charger, I changed the battery, but I am not sure that the battery charger may not be repaired. It affects the glass control panel.
08.05.2020 19:09 # 4
berk2309
Did you charge the charge at normal levels?
08.05.2020 19:09 # 5
ondoz
[QUOTE]
If you carefully remove the window control from its socket, open the inside and clean the places where the full keys touch, the window control improves.
ondoz 2015-03-14 00:28:54
