|   | EL brake and stop warning light come on |
| 08.05.2020 20:52 | # 1 |
|  Murattemiz71 | |
| 08.05.2020 20:52 | # 2 |
|  sonerkyl | |
Hodja most likely the product in the line is defective for example purposes. the car lights up the stop light because it thinks the brake is drawn.  | |
| 08.05.2020 20:52 | # 3 |
|  Murattemiz71 | |
I understood, I thought it was brake fluid, which makes sense
| 08.05.2020 20:52 | # 4 |
|  sonerkyl | |
[QUOTE = Murattemiz71] I understood, I thought it was brake fluid, which makes sense [/ QUOTE]   you are welcome, look at the brake hydraulic level :)   | |
| 08.05.2020 20:52 | # 5 |
|  KILIC | |
I think the brake fluid may be low, have it checked.
| 08.05.2020 20:52 | # 6 |
|  onlycihan | |
brake fluid shortage almost fails this in almost every vehicle
| 08.05.2020 20:52 | # 7 |
|  talip206 | |
Brake fluid decreases, especially if it is on a hill. But the point you should be aware of is that there is a leak in a place where the hydraulic stops and stops. Lean under the car and observe the back (inside) of the wheels. If oil has flowed into the tire, there is a leak in one of the brake centers.   There's another possibility. If there is a sender who measures the level of the coolant, if the water is diminished, it will also give an alert when it comes out. Water level sensor is not in all models. I know that it's usually in diesel.  | |
| 08.05.2020 20:52 | # 8 |
|  Murattemiz71 | |
thanks I added hydraulic problem solved  | |
| 08.05.2020 20:52 | # 9 |
|  talip206 | |
[QUOTE = Murattemiz71] thanks I added hydraulic problem solved   If there is a drop, there is a leak somewhere. Do not forget, I wrote above, the matter of braking is important. Lean under the car and check the interior of the wheels for oil.  | |
| 08.05.2020 20:52 | # 10 |
|  Murattemiz71 | |
I guess there is a leak, I added hydraulics and after a while it started to burn again. I think there is a leak in the middle rather than towards the tires. There is a leak from the middle part of the vehicle, can there be a brake center?
