EGR VALVE CANCELLATION
08.05.2020 17:13 # 1
DS002
If friends canceled the egr valve, it prevented the institution in diesel vehicles, but if it was a little bit of a performance, it was true. What are the damages of the bidet egr valve cancellation? can you inform me about this topic
08.05.2020 17:13 # 2
DS002
Alla alla, so much smoke when I canceled egr?
08.05.2020 17:13 # 3
DS002
I will try it on the weekend, if it throws smoke, I'll be right back and I will do it when I hear the performance increase & nbsp;
08.05.2020 17:13 # 4
When you cancel the Egr valve:
& nbsp; & nbsp; & nbsp; & nbsp; 1. Fuel saving on straight road at constant speed.
& nbsp; & nbsp; & nbsp; & nbsp; When going up to the 2nd bay, the savings from item 1 are returned. It is even damaged.
One purpose of the Egr valve is to reduce the temperature of the combustion chambers. This reduces stress anywhere from the gasket to the exhaust manifold.
I do not recommend.
08.05.2020 17:13 # 5
inceyasar
i have no smoke problem plus the car has powerbox egr canceled & nbsp;
08.05.2020 17:13 # 6
jack67
For egr, I went to the industry today, they asked for 50 liras to clean, and the new one asked for 50 liras to install a 105 TL master.
08.05.2020 17:13 # 7
DS002
Is there no problem after the egr cancellation in the vehicle?
08.05.2020 17:13 # 8
inceyasar
After the EGR cancellation, the 1000 to 1500 rpm vehicle has been revived more generally, the vehicle is more serial.
08.05.2020 17:13 # 9
DS002
So, I wondered why there was black smoke in the car of Bursa 307. Can you explain? I have to be enlightened about this subject because I am thinking of doing the weekend.
08.05.2020 17:13 # 10
serkan719
where is 206 hdi da egr exactly. Not under the diesel filter. at the back of the engine. You cancel the
cancellation by removing the gasket.
