EGR FAILURE
08.05.2020 20:36 # 1
mihrali_06
FRIENDS GET EVERYONE
THERE ARE A FREQUENTLY CAUSED THERE, BEFORE THE COOLS OF THE AIR IN THE LAST TIME, THE CAR WORKS IN THE MORNING OF THE EXHAUST FROM EXHAUST TO WHITE TO BLUE, EXTREMELY TO THE BLUE.
I HAVE BEEN ATTENTION IN ONE WAY, I WON'T GET UP TO 4 `` WHEN I NEED TO KEEP UP THE HIGH SPEED 3 '' (THERE IS 3 THIRD (3000-3500 RPM) VITEST OUR EXTENSION ON THE BLACK AND SMOKE PUMP, I HAVE TO KEEP ANYMOUS AND THERE ARE THERE ARE THERE ARE THERE ARE THERE ARE THERE A LOT OF SMOKE PUMP I HAVE CHECKED IT HAS BEEN 2 WEEKS PROBLEM NO REMOVED WHERE IS THE UNRIVERABLE EGR VALVE IN THE VEHICLE PART OF THIS PROBLEM? DOES THE EGR VALVE REQUIRE CLEANING OR NEED TO CLEAN, DOES THE FAULT LAMP BURN IT OR DOES IT KNOW THAT WITH PROBLEMS?
YES SOURCE COURSE, I AM EXPECTING ITS SUPPORT FROM THE FORUMISTS WHO HAPPENS TO US WITH THE REPAIR OR THE ORIGINAL ZERO SUPPLY.
BEST REGARDS. . .
08.05.2020 20:36 # 2
Hello, brother. Firstly, it is forbidden to write in capital letters due to forum rules. As you said possible, it seems to be caused by the egr valve. There is no oil and water reduction in the vehicle? trotter price is around these. you can cancel it. Roughly rough workmanship etc. around 180 TL. The amount of around 250-300 TL varies according to the procedure to be done and if the extra is not available.
08.05.2020 20:36 # 3
mihrali_06
Sorry, I did not know, soner bro, there is no oil and water reduction in the vehicle, only after checking yesterday, the pipes that appear in a slightly oil-bending place not on the engine cover are not so little but not a little, but if I cancel it, my soner is a problem. will it keep you alive later
08.05.2020 20:36 # 4
Orcun.Dmr
I canceled, teacher, there was no problem and there was a noticeable revival in the lower ages. Have you checked the turbo? It causes the exhaust of the exhaust in the worn turbo.
08.05.2020 20:36 # 5
mihrali_06
I suspect the master from the turbo Orçun brother will look when the financial situation improves, but it seems like a solid problem appears in the turbo + I also spent the whole car in terms of egr turbo + egr and the oil leak from the turbo as if the black box turbo under the engine cover and entering them Visibly lubrication has occurred on the pipes recently
08.05.2020 20:36 # 6
turbo hoses may be missing. When my teacher registers over time, he can get out of there.
08.05.2020 20:36 # 7
mihrali_06
Thank you soner when I do a general maintenance repeat, the master will also consider these. I always buy shellvpower nitro in my fuel, I hope I don't have any emission problems
08.05.2020 20:36 # 8
Orcun.Dmr
No, teacher, you will not have any problems with emissions, which is 0.35.
08.05.2020 20:36 # 9
[QUOTE = mihrali_06] Thank you soner when I do a general maintenance repeat, the master will also consider these. I always buy shellvpower nitro in my fuel, I hope I don't have any emission related problems [/ QUOTE]
You are welcome, my teacher. but I advise you not to constantly buy nitro diesel. full save will be sufficient and your fuel consumption will decrease.
