Efe master of the masters
08.05.2020 15:10 # 1
insomnia
I don't have ABS in 306. I am very complaining about braking in rainy weather. I usually use serial cars.
08.05.2020 15:10 # 2
peugeotefe
There is nothing to do as soon as it is done but it requires a lot of effort and it will not be useful in costly abs. Normally the brakes of the 306 are good. What are the tires and wheels in your vehicle?
08.05.2020 15:10 # 3
insomnia
My master tires have replaced my new 185 65 14 rims, but the front pads are locked when the floor is wet, even my burakbey did not lock so early.
08.05.2020 15:10 # 4
peugeotefe
If you install 4 steel rims on the vehicle provided that they are 15 '' or 16``, you will get 100% 80% of aquaplaning problem if you buy 4 beautiful tires.
08.05.2020 15:10 # 5
insomnia
Efe master, I am planning to buy my 14-inch 5-spoke wheels, if I buy 15-inch, I would cut this new problem in 4 of them.
What should be the choice of additional tires and wheels, master
08.05.2020 15:10 # 6
peugeotefe
Let me give an example from my own car. I have a peugeot partner car. There were 14 wheels we used. There were zero michellin tires. 185/65/14 was obviously sled 16 ''. The size of the base is 195, so it will be more beautiful.
08.05.2020 15:10 # 7
3rkans
Efe gti buffer still not available?
08.05.2020 15:10 # 8
peugeotefe
no unfortunately
08.05.2020 15:10 # 9
insomnia
[QUOTE = peugeotef A]
plus 4 pieces of rubber will be needed, I don't understand, I don't understand that there was 13 inch wheels and tires in my burakbey. had said to fix it with
efe master What do you think about this disk turning event, will I get some improvement?
08.05.2020 15:10 # 10
oguzhan29
my car's pads and discs have changed during the maintenance of 120000 in the service, but the front right side pulls out early it closes early in the service, so what happened?
08.05.2020 15:10 # 11
Efe brother,
I'll ask a question, too. In my 307 1.6 16v vehicle, I think it sounds like one of the valve thrusters called cup. What does the valve tappet for 16 petrol engines cost? If juz is something, this sound has no harm but I prefer it not. Thanks.
08.05.2020 15:10 # 12
[QUOTE = insomnia] My master tires new 185 65 14 rims have replaced the last front pads, but the ground locks when it is wet, even my burakbey did not lock so early.
I guess your tires are not very good quality. I have abs in my vehicle, but it would be very rare. and one of my tires 2005 other 3 u 2006 production could be counted in half, besides the bridgestone B330 :) :) I used another 306 in the past, 16 "rim kumho ecsta spt (ku31) was fitted with a new tire and alcal. If it was crazy, my grip was much weaker than my car.I couldn't give a meaning too ... but the tire is a very important factor.
08.05.2020 15:10 # 13
insomnia
[QUOTE = cecoli] [QUOTE = insomnia] My master tires have replaced the new 185 65 14 rims, but the front pads are locked when the floor is wet, even my burakbey did not lock so early. The only tightness was braking in this vehicle [/ QUOTE]
cecoli master, if I am not mistaken in tires, I will take a good look at the model and numbers. I do not know how important this production date is for clutching and braking.
08.05.2020 15:10 # 14
It would be wrong to talk about the tires without seeing them. but if the rear tires are newer, replacing may be helpful.
08.05.2020 15:10 # 15
insomnia
It would be wrong to talk about [QUOTE = cecoli] tires without seeing them. but if the rear tires are newer, replacing may be helpful ... [/ QUOTE]
efe master told me that I will solve it with rim and tire, this will cost me dearly but I always respect what my master said.
When it comes to the pictures, I will load it at the first opportunity
08.05.2020 15:10 # 16
It would be wrong to talk about [QUOTE = insomnia] [QUOTE = cecoli] tires without seeing them. but if the rear tires are newer, replacing may be helpful ... [/ QUOTE]
it's true what he says. 195 55 If you buy a 15-piece tire, the most guarantee will be the solution. This means an average of 170-180 rubles of rubber for a quality tire. 500 patterns on wheels are an average of 1200 TL. but it would be like a stapler ...
08.05.2020 15:10 # 17
insomnia
[QUOTE = cecoli] [QUOTE = insomnia] [QUOTE = cecoli] It would be wrong to talk without seeing the tires. but if the rear tires are newer, replacing may be helpful ... [/ QUOTE]
cecoli master, this is my plan B for now
08.05.2020 15:10 # 18
3-channel waterway, soft paste, 195 base holds 55 cheeks like a cat.
08.05.2020 15:10 # 19
insomnia
[QUOTE = mustafakirl of]
It is important to stop the car as much as speeding up. I have been handicapped about stopping at me. I did not like the possible brake. I did not see. I can not solve.
08.05.2020 15:10 # 20
Okay, you have to get the best ones among the tires first, to the side ... That's the plan A ...
Page : / 3
