economic mode |
| 08.05.2020 16:58 | # 1 |
slmlar friends ... i have 307 trptnck gear 1.6 2007 model..with economic mode on the screen and the car is running new battery no problem mars basior but thanks for whatever the reason may be, thank you in advance ... < / P> |
| 08.05.2020 16:58 | # 2 |
If it does not start and take off, it may be immodan. Try a backup key.
| 08.05.2020 16:58 | # 3 |
I tried, the brother did not have a spare key .. |
| 08.05.2020 16:58 | # 4 |
vehicle eco fashion night teacher, dynamo or akude problem, look at the poles, can there be oxidation or something or it will be on the vehicle
| 08.05.2020 16:58 | # 5 |
I have no brother, we saw how many days & nbsp; the battery is normal, the battery is normal ... auto electricity came, we put it into the computer. strong basior genede almior ecomomic mode text next to the strange ...
| 08.05.2020 16:58 | # 6 |
worst of all, then there is a problem in the brain or there is a problem in the connective of the dinamon
| 08.05.2020 16:58 | # 7 |
Alicilik |
The 206 is also under the steering wheel, but at 307, I don't know where the BSi box is. Check the fuses on it. My tape's fuse was blown, we could not start the vehicle when the fuse changed. |
| 08.05.2020 16:58 | # 8 |
Fuel may not be coming to the vehicle, it has nothing to do with eco mode. My vehicle passes every day. There is no problem while working in eco mode.
| 08.05.2020 16:58 | # 9 |
Thanks guys, I will see you again in the morning ...
| 08.05.2020 16:58 | # 10 |
istanbullu_3886 |
volant pulley reader can make from sensor
| 08.05.2020 16:58 | # 11 |
EErgul |
my 206 also got into eco mode while standing still. or I did not know. ECONOMIC MODE ACTIVE wrote on the information screen. How do I switch to normal mode again? & nbsp;
| 08.05.2020 16:58 | # 12 |
[QUOTE = EErgul] got myself in eco mode while my 206 stopped. or I did not know. ECONOMIC MODE ACTIVE wrote on the information screen. How do I switch to normal mode again? & nbsp; [/ QUOTE] If my 206 also works when the contact is off, the tape will not work on the screen after a while. If I try to turn on the tape again, the same warning comes up and this time the tape does not work at all. this warning disappears if I switch the ignition on and off and start and stop the vehicle. If I turn on the tape while the vehicle is not running again, after a while (about half an hour), the economic mode active warning appears and the tape turns off. if I think this event is for protecting the electric-battery system. it is not worth it. my best regards.
| 08.05.2020 16:58 | # 13 |
friends eco mod does not switch off electric contact in some peugeot. When the ignition is off, the tape will run at certain intervals. I think it is a bit of a password in the end of the game, maybe there is a problem or immobilizer fuse has blown out.
| 08.05.2020 16:58 | # 14 |
EErgul |
[QUOTE = hema123] [QUOTE = EErgul] got myself in eco mode while my 206 stopped and stopped. or I did not know. ECONOMIC MODE ACTIVE wrote on the information screen. How do I switch to normal mode again? & nbsp; [/ QUOTE] If my 206 also works when the contact is off, the tape will not work on the screen after a while. If I try to turn on the tape again, the same warning comes up and this time the tape does not work at all. this warning disappears if I switch the ignition on and off and start and stop the vehicle. If I turn on the tape while the vehicle is not running again, after a while (about half an hour), the economic mode active warning appears and the tape turns off. if I think this event is for protecting the electric-battery system. it is not worth it. with my best regards. [/ QUOTE] yes yes this was not a problem. I read in the user manual of the vehicle; If the car is going to save mode, when the ignition is on, if something that eats the battery such as tape headlight, etc. is working, it goes into saving mode and locked the battery after 30 minutes. When you start the car again, it comes out of this mode. I thought it was in eco mode. speed limiter or something comes into effect :)
| 08.05.2020 16:58 | # 15 |
Economy mode is only available to prevent the battery from falling down from a certain level. Otherwise, it should not be nice to be faced with a situation such as your vehicle not receiving a starter when you press the starter. Economy mode has nothing to do with the car's dorm, the draft. |
| 08.05.2020 16:58 | # 16 |
metin |
You should thoroughly clean the battery terminal. Even if there is a small non-contact, the functions of the vehicle will work but do not start. Experience is stable. & nbsp; It has nothing to do with the operation of the vehicle. its purpose is just to prevent the battery from running out. & nbsp;
