Eco mode vehicle does not work
08.05.2020 21:00 # 1
Krgzsmtx
friends peugeot 206, i tried to start the car in the morning, there is no problem in the show, but eco mode is printed on the instrument panel of the radio.
08.05.2020 21:00 # 2
Selcuk55
Eco mode is the battery protection circuit does the car never start?
08.05.2020 21:00 # 3
Krgzsmtx
the vehicle never broke down
08.05.2020 21:00 # 4
talip206
[QUOTE = Krgzsmtx] never pressed even if the vehicle did not hit [/ QUOTE]
Your battery is exhausted.
08.05.2020 21:00 # 5
Kysr038
It happened to me in the winter
I lost the vehicle on my own
as well as running it.
I lost the vehicle through the driver's door with the ignition on.
It was easy to lose the vehicle when it came to a very slight slope
I continued to lose a little running consistency and jumped into it
I pressed the clutch and took the Gear 2
When I was going to do half clutch, the vehicle worked on its own
I pulled my foot off the clutch and put it on the gas
I've never done before
Especially alone
I think now it's a little crazy
08.05.2020 21:00 # 6
maximusti
Even if the headlights stay on normally, ECO turns off the headlights when it enters the mode. to store enough battery energy to start the vehicle.
If the battery has a problem, it may have discharged itself.
Run the jump starting tool, if you still encounter the same problem, try replacing the battery.
08.05.2020 21:00 # 7
most of all, the battery that our friends have said has completed its life. bro you will need to change.
08.05.2020 21:00 # 8
Krgzsmtx
I think I found the problem, all the lights on the front console do not go out, it probably remained on until the morning
