ECCENTRIC TIMING (SENT SET) 2
08.05.2020 13:58 # 1
Correct timing of the camshaft is important. Timing values are taken, summed, added 180, and the result is divided by 2. First timing value for intake is extracted, second timing value for Exhaust.
Example: 270 Ford SOHC
SUCTION 23/65 EXHAUST 65/23
23 and 65 add up = 88 Adds 65 and 23 = 88
180 is added = 268 180 is added = 268
Divided by 2 = 134 Divided by 2 = 134
23 subtracted = 111 23 subtracted = 111
SUCTION VALVES SHOULD BE FULLY OPEN AFTER 111 °. EXHAUST VALVES SHOULD BE FULLY OPEN 111 ° BEFORE.
Place the protractor on the crankshaft to be reset at TDC. Position the gauge on the valve spring retainer as well. Turn the engine until the indicator shows full lift value. After checking how many degrees you are rotating, continue turning until full fall is observed on the lift. Actual full lift value is the point between it. For example, if the full lift value is observed between 105 ° and 115 °, the actual full lift value will be 110 °. For a single eccentric motor, it is sufficient to check the intake valves only.
WARNING
It is also important to replace the timing belt if a new camshaft is installed. However, the timing belt should also be changed at the intervals specified by the manufacturer. Any problem caused by the timing belt can cause great damage to your engine in seconds.
08.05.2020 13:58 # 2
sinan-s
Nice share..
08.05.2020 13:58 # 3
Best Service Muzaffer Doğrular with the contributions of us :)
