eac fail error
Homepage » PEUGEOT MODELS (FAULTS AND SOLUTIONS) » Other Brands
08.05.2020 18:24 # 1
KIZILASLAN
friends my other vehicle is eac fail error in 2004 1.4 tdci fiesta. we took the repairman worked for 3 days but could not solve the problem, the vehicle interrupts the error and when it fails, eac fail is written on the screen and the vehicle does not exceed 3000 cycles, it drops from the traction, it turns off the ignition and returns to normal after running for a while ... I am waiting for the help of friends who have knowledge about this subject, whether our vehicles have the same engines.
08.05.2020 18:24 # 2
spearo
eac fail = elektronic actutator control fail, means, has 3 reasons
1. battery is not charging. if the battery drops below 12v, it protects itself from this error
replace your battery passes;)
2. Before the suction throat, the butterfly is broken, replace it passes
3.If the electronic accelerator pedal is defective, it gives this error. Replace the accelerator pedal.
Spearo 2014-03-23 19:21:43
08.05.2020 18:24 # 3
KIZILASLAN
tomorrow we will replace my 307's air mass meter with his and see if the problem will be fixed
08.05.2020 18:24 # 4
spearo
maf sensors are not the same,
You are interesting though I don't write down the reasons for you in order of control ... it is a known fault that you can detect in half an hour ... good luck!
08.05.2020 18:24 # 5
KIZILASLAN
The problem is solved. I changed the air mass meter (maf sensor) of my 307 with that of the fiesta.
08.05.2020 18:24 # 6
KIZILASLAN
[QUOTE = bitter] maf sensor does not give this error strange thing ..
we did not understand, but we said let's try, I was looking for a little bit, a few more people solved the fault in this way, I hope it was solved in ours :) It has not worked for 2 days, it is working normally
