dust odor from the air conditioner
08.05.2020 19:53 # 1
x571
When I turn on the air conditioner, there is a smell of dust, can I do something to it?
08.05.2020 19:53 # 2
xmen
Replace when the pollen filter was last changed, not changed recently. It is probably full of dust ...
08.05.2020 19:53 # 3
x571
[QUOTE = xmen] Replace when the pollen filter was last changed, not changed recently. It is probably full of dust ... [/ QUOTE]
I don't know at all, it's been 4 months. the estimate has been 2 years. Can I make this filter for 306 1.6 gasoline? how can we change it?
08.05.2020 19:53 # 4
xmen
My teacher probably doesn't have a pollen filter in your vehicle. evaluate the results of some research on the internet ...
08.05.2020 19:53 # 5
Adem Kurtuldu
It is something of 10/15 TL. If you know that place, you can even change it by yourself.
08.05.2020 19:53 # 6
ssakyel
Sometimes the air ducts that have not been cleaned for years can smell. If you change the pollen filter, there is an air-conditioning duct cleaning foam.
08.05.2020 19:53 # 7
x571
[QUOTE = Adam Kurtuldu] It is something of 10/15 TL. If you know it, you can even change it by yourself.
There was no filter in 306. If anyone knows why dust smells and how to fix it, I am waiting for help.
08.05.2020 19:53 # 8
xmen
[QUOTE = x571] [QUOTE = Adam Survived] It's something 10/15 tl. If you know it, you can even change it yourself. 206 is behind the fender on the right, but I don't know where it is at 306, maybe it's the same [/ QUOTE]
Hodja, if it has been used in the same way for years, it can smell dust. There are air conditioner cleaning sprays you can use from them ...
08.05.2020 19:53 # 9
x571
[QUOTE = xmen] [QUOTE = x571] [QUOTE = Adam Survived] It's something 10/15 tl, if you know it, you can change it yourself, 206 is behind the fender on the right, but I don't even know where it is at 306 [/ QUOTE]
Hodja, if it has been used in the same way for years, it can smell dust. Air conditioner cleaning sprays are available from them ... [/ QUOTE]
Is there a product you are satisfied with using?
08.05.2020 19:53 # 10
xmen
There are many products on the market. I have used it before, but I don't remember its name. You can get the product you want to buy by looking at the comments ...
08.05.2020 19:53 # 11
tigerland
There are silver ion sprays, you open the air conditioner with the doors open. I would recommend getting into the A / C pipes.
08.05.2020 19:53 # 12
OguzhanKucuk61
I heard those who smelled the auto perfume into the pollen filter :)
08.05.2020 19:53 # 13
x571
[QUOTE = OguzhanKucuk61] I heard those who smelled auto perfume into the pollen filter :) I do not know how it is for health but it will definitely prevent bad smell [/ QUOTE]
There is no pollen filter in the vehicle. It is not worth it: D or replace it.
08.05.2020 19:53 # 14
Cyrus35
Even if there is no pollen filter, there is a place where the air draws the air, when you lift the hood, if you clean the duct with a blast gun, or a place like a duct, or at least under the console, you can clean the duct where the air comes from with an air gun or even from the outside when driving with something like a cotton sponge or polyester cotton as a filter. you can prevent dust soil from coming
08.05.2020 19:53 # 15
x571
[QUOTE = Cyrus35] If there is no pollen filter, there is a place where the air draws the air, when you lift the hood, if you clean a duct like a duct or under the console at least under the console, you can clean the duct with an air gun or even a sponge or polyester cotton as a filter by yourself. you can prevent dust from coming outside while driving with something like this [/ QUOTE]
I found an entrance like this in front of the passenger side when it was tampering. It turns out when I remove the mattress under the wipe. I think you have to remove the grille from the wipers to remove it completely. Is that where you call the console under the torpedo or something?
08.05.2020 19:53 # 16
Cyrus35
I do not know the 306 air conditioning console, if there is internal and external ventilation, there is both a duct in which the air is drawn inside and a duct in which it draws air from the outside. the inner duct is generally under the gear bellows part, under the foot parts, the outside ventilation grille is somewhere under the glass wipers when I open the hood, I think it could be tampered with for you if there was a 306 near me but unfortunately there is no possibility to find a scheme if you do a research in the form of air conditioning fan hose ventilation. Smile
08.05.2020 19:53 # 17
x571
Tell me I'll make a comeback. I guess the air ducts were dust because the air conditioner was not used for a long time. In the summer, when using plenty of air conditioning, the dust event completely ended.
