DUMP VALVE (Lecture in Simplest Language.)
08.05.2020 13:55 # 1
Dump Valve is a piece that is produced to increase the gas response by keeping the turbo pressure high in turbo-fed cars.
In cars with turbo feed, the turbo still rotates when the foot is pulled out of the gas, but the high pressure that occurs due to the fact that the air pressed by the turbo does not have a place to go, suddenly slows the propeller by applying a great force to the turbo propeller. When you press the gas again, it is necessary to accelerate the propeller again so that the turbo pressure can reach its peak, and during this process, a great performance loss occurs because the desired turbo pressure cannot be achieved. Dump valve is there to prevent this performance loss.
Does it work at Dump Valve?
The benefits of Dump Valve?
* It prolongs the life of the turbo by preventing negative back pressure on the turbo propeller.
* It keeps the turbo pressure high by preventing the speed of the turbo propeller to slow down. High turbo pressure means high power.
* It provides added power as it exhausts the old heated air between exhausting and depressing and takes in the new, cold air.
08.05.2020 13:55 # 2
thanks for sharing Wink
08.05.2020 13:55 # 3
blow off valve briefly
08.05.2020 13:55 # 4
mad_sho
I will give you a good health
some of our friends have a question mark in their heads
Does it have an effect on fuel consumption? DIe
it has no effect, it has the benefit as it writes on the contrary window.
get additional information, i wrote it has been useful
