Due to the problem in the gas gauge version yuk
08.05.2020 15:02 # 1
sercinho
mrb friends I have written before that I have a question about my benzine, I have a question about it. I do not work properly. It looks crimson, it is finished, it is showing that the service with the electric master has not been shown to me, the version has to be reloaded and it is corrected in such a way. If there are other friends who experience this leakage, I am waiting for their help and solutions.
08.05.2020 15:02 # 2
F-Eren
float is no problem?
08.05.2020 15:02 # 3
sercinho
I asked, says no, I do not understand too
08.05.2020 15:02 # 4
Allah Allah buuz :) :) Another one of the troubles experienced with the increase of the electron ... If we learn something new every day, we hope ... well, I hope you will get out in a short time ...
08.05.2020 15:02 # 5
sercinho
I hope the version will be solved with the upgrade, but I do not fully understand I hope there is a fee of 50 TL.
08.05.2020 15:02 # 6
dbmaster
If you take gasoline under 7 liters, it will not play.
08.05.2020 15:02 # 7
sercinho
I don't understand, I have to have 7 liters at a time. I bought 20 liters of gas twice. There is no click. We have to take 7 liters at a time.
08.05.2020 15:02 # 8
dbmaster
7 liters and above in one go, you can buy 10 times, fill the 20 lira gas tank, burns red again
08.05.2020 15:02 # 9
dbmaster
Tomorrow you will go to 30 TL to get the gas by adding the gas in me.
08.05.2020 15:02 # 10
What is the scientific reality of this seven liter event? So why doesn't the pointer move to less than 7 liters? The result is not a samadira mechanism?
08.05.2020 15:02 # 11
dbmaster
this 7 liter incident is the amount processed into the vehicle's brain, and the float is connected to the electronic brain. This is 100% real, you can ask the authorized services.
When it comes to my personal opinion, it is not easy to buy 7 liters in a country where the flowing fuel is so expensive, but there is nothing to do with the structure of the vehicle.
A short example: you go now, take 15 lira and take another 15 lira on a tour, 30 lira but it does not play, after the fuel is put, the contact resets the event, it sees 7 liters in filling, but 15 + 15 and 30 lira on it. 60 pounds, pounds of 60 pounds of gasoline is thrown like ...
Very interesting.
08.05.2020 15:02 # 12
metin
The float measures and transmits it to the brain if it changes in volume only when we buy gasoline. If you take it under a certain limit, for example, as our dbmaster friend said, under 7 lt, the buoy does not detect the change and does not say gasoline is taken to the brain, it does not raise the needle in the brain. I bought 15 + 15 + 20, but it didn't play but when I get 50 at a time it will be officially ((
As a result, do not take 20 TL, do not play, take at least 30 or even 40 TL or have the parts showing the gasoline available whenever the ignition is opened on vehicles with LPG (:
08.05.2020 15:02 # 13
In this case, the trip computer also shows wrong, is it? For example, with the current tank, you can go a few more kilometers wrongly, if less than 7 liters are taken.
We learn new things every day.
08.05.2020 15:02 # 14
metin
yes it shows wrong. The needle continues to fall from where it left off, as if you had never taken petrol, it just shows how far it will go with the previous petrol.
In short, it continues to fall from where it left off as if you had never taken gasoline.
In our beautiful form, there are so many issues related to peugeot, if you research, you will know your vehicle and you will find out how and where to solve the malfunctions that occur most smoothly and with minimum cost, you will love it rather than cooling it from your car.
quiet_20 2011-01-18 10:04:01
08.05.2020 15:02 # 15
dbmaster
Yes, this 7 liter incident should be in everyone's mind, so don't be surprised if you get a minimum of 7 liters at a time, or the medicine will continue to fall just like that ...
08.05.2020 15:02 # 16
sercinho
friends, I bought a 35 TL gasoline today and it will be okay, we will not get 7 lt down, I think it would have been done, I think it would be connected to your brain and this lt event could be adjusted.
08.05.2020 15:02 # 17
metin
[QUOTE = sercinho] friends have bought 35 TL gasoline today, and it looks like we will not get 7 lt down, so I did a bit of a scissor, I think they would be doing this in the service.
sensible. I think I'll say a research. We have brothers and sisters who have the same problem with you and do not know the solution.
08.05.2020 15:02 # 18
3rkans
I have the same problem, too, I suddenly get up or I also see red.
08.05.2020 15:02 # 19
BAHTIYAR
try what i said friends do not add parts that spoil the originality of the vehicle in vain, from the simplest logic to a complex system you are adding another system, the risk of failure increases 100 lira gasoline, let's see what happens / believe it in the summer i was in the same trouble tink gives warning, it says it is not finished then it gets 100 lira fuel check they gave me 100,000 pounds of gas, passed half a tank for 4 months, although I bought no gas for 4 months, I added 20 or 30 pounds every month when I stopped and opened it, there is no problem. You can give 100 pounds of gasoline to 100 lira for that tool. Better / good evening
08.05.2020 15:02 # 20
metin
You have to try 06BAHO you may be right. Then, since other friends say that they don't have a pointer and you stay more than half, I think it is necessary to get at least 7 liters when these vehicles are below a certain level. I'll try what you said. I am not happy if I had a module installed for my hand to lift up. If it will be like yours, there is no need for a module. I will try a logical application at the first opportunity.
Page : / 2
