drum painting |
| • Homepage » PEUGEOT MODIFIED PLATFORM » Modification and Tuning Information | |
| 08.05.2020 15:37 | # 1 |
Greetings to all, 10 days ago, I think I painted the drums and front calipers. I think if I want to overhaul the wheels, can I get under it? |
| 08.05.2020 15:37 | # 2 |
voodoo |
Stay the rims first, then you will be fine with two hand sandpaper ... then you will fill the masses with great masses ... then you will be sanded beautifully again ... you will hit the last paint but the quality in the paint ... of course you need a bit of mastery to do these. ..Good luck with...
| 08.05.2020 15:37 | # 3 |
voodoo |
Bidet first you need to introduce yourself ... as per forum rules ...
| 08.05.2020 15:37 | # 4 |
I have heard of steel fillers as tşkler peiki filler but is this suitable ..
| 08.05.2020 15:37 | # 5 |
voodoo |
Well, I don't know what's in it ... but two items are mixed together ... another red solution comes into the kit ... they mix and fill the two ...
| 08.05.2020 15:37 | # 6 |
voodoo |
But do not forget that the fillings remain with the full rim in the abrasive, which leaves very little ....
| 08.05.2020 15:37 | # 7 |
thanks
| 08.05.2020 15:37 | # 8 | |
Sec. ykanar 87, The rules say:
| 08.05.2020 15:37 | # 9 |
I talked before and started to introduce myself
| 08.05.2020 15:37 | # 10 |
[QUOTE = ykanar87] I talked before and by introducing myself, by introducing the subject [/ QUOTE] Can you send the link of the subject you are doing? Since I couldn't find it, I needed to remember. |
| 08.05.2020 15:37 | # 11 |
http://forum.peugeotturkey.com/forum_posts.asp?TID=14710&title=206-gs you can look at this location ...
| 08.05.2020 15:37 | # 12 |
| 08.05.2020 15:37 | # 13 |
You Spend Good Labor, Have Health Fekat But But You Have Read The Life Of BOHEME
| 08.05.2020 15:37 | # 14 |
What do you call BOHEME?
| 08.05.2020 15:37 | # 15 |
First of all, welcome to us. and it would give you a better idea if you pulled the vehicle over.
| 08.05.2020 15:37 | # 16 |
yeditepely |
[QUOTE = ykanar87] Greetings to all, 10 days ago, I think I painted the drums and front calipers. I think if I want to overhaul the wheels, can I get under it? [/ QUOTE] Links are dead my friend :( I couldn't open
| 08.05.2020 15:37 | # 17 |
I couldn't look too
| 08.05.2020 15:37 | # 18 |
I had seen the subject first when it opened, but I could not write cvp. It is nice. When I was painting, I did as follows. the previous color was bad. At first I dropped the paint on it by hitting it with a hammer. then I cleaned the drums with a fine water sander. I did not use primers or varnish. I painted it with a good quality spray paint. I passed the first floor and left it to dry a little, then I passed the second floor and it was like cirlop. respects |
| 08.05.2020 15:37 | # 19 |
yeditepely |
[QUOTE = pugti] I had seen the subject first when it opened, but I couldn't write cvp. It is nice. When I was painting, I did as follows. the previous color was bad. At first I dropped the paint on it by hitting it with a hammer. then I cleaned the drums with a fine water sander. I did not use primers or varnish. I painted it with a good quality spray paint. I passed the first floor and left it to dry a little, then I passed the second floor and it was like cirlop. respects [/ QUOTE] In other words, my friend is a fine water sandpaper that is necessary for us.It is a high quality paint. Then I don't have to do two jobs :)
| 08.05.2020 15:37 | # 20 |
You will not hold much, do not drop your hand once in one place .. In my application, 2 boxes, 2 calipers, 1 box was enough. |
