drowning - after maintenance -
08.05.2020 17:15 # 1
msk_sansal
hello & nbsp;
307 1.6 hdi owner i had my car periodic maintenance & nbsp; oil + filter group changed but there is a difference in the car since then. As if it was a reluctance at around 2000 rpm, I went to the master again today. I even listened to the exhaust while I was getting something from the baggage. it sounds like a hoarse voice. what could be the problem
yag total 10 40 was set up & nbsp; I will say the sound different than this, but the car that needs to be picked up in 2000 revolutions is like annoying :( it's not that much and & nbsp; I couldn't come up with a solution.
08.05.2020 17:15 # 2
Serkan
Sir, are the filters you used original?
08.05.2020 17:15 # 3
msk_sansal
He said it was original but I doubt it. & nbsp;
08.05.2020 17:15 # 4
Serkan
As you know after the maintenance, the vehicle should be better relaxed, it looks like a turbo shortage, but it is difficult to say exactly, it is my advice for the next maintenance, take the filters yourself and go to the master for workmanship only, use 5/40 full synthetic oil in the oil. < br>
08.05.2020 17:15 # 5
msk_sansal
Master how many years I have friends for the piece, as I said, orj. It is kullanmıyt. You won't be a friendly scratch. me the first air filt. bidet turbo arrived. 2 masters looked at the turbo, both said good. The effect of turbo is already understood. & nbsp; I will ask the service on the day but I realized what the exhaust was when my teacher drowned the baggage from the trunk. & nbsp;
08.05.2020 17:15 # 6
Serkan
Let's see what the service will say, was the engine cold when you noticed the sound
08.05.2020 17:16 # 7
msk_sansal
No, my brother was around 75 to 80, so engine heat always
08.05.2020 17:16 # 8
Serkan
It is interesting to be after the maintenance, when I go back, I said that the master got on and tested it and the situation was normal.
08.05.2020 17:16 # 9
msk_sansal
He said exactly the same, he even put the air filter or something. He said it could be from fuel. I even did the usual standard operations, even Gardas said ... I did not consult the service, I would change the filters again. It is said that the exhaust sound is changed or ins is not a problem with exhaust connection.
08.05.2020 17:16 # 10
Serkan
My teacher is not psychological, after all, you have an expectation after the maintenance, I sometimes think that there is a problem with the vehicle, but I will not forget anything, then I will forget, if there is someone who knows the vehicle in the family or in the immediate vicinity, they will use it a little.
08.05.2020 17:16 # 11
msk_sansal
My teacher used the same reaction in them, we even noticed the change of voice with my friend.
08.05.2020 17:16 # 12
Serkan
I don't think there is anything about maintenance, let's see what the service will say, I hope there is nothing expensive.
08.05.2020 17:16 # 13
msk_sansal
Let me share the result from here with your permission.
Thank you.
08.05.2020 17:16 # 14
tuuncii
my car gasoline I put 10/40 oil but you said 5/40 sheep what is the difference? Can we put the oil we want in the bidet in this way?
08.05.2020 17:16 # 15
msk_sansal
I went to the Authorized Service today and the problem was SOLVED. they didn't care about the air suction-thrust, there was no hose left, then they said that the air filter box's hose was loosened, they took care of it, I tried it, I said really thank goodness. As if there is a problem of drowning, it is more like a less drowning sound. When I have a problem, it seems like a drowning sound is going down to 3000 revolutions while it is at idle, it is also in gear, when it is under load .... in the same way when it drops to idling in idle and gear .. anyway & nbsp; 90% gone. .
I know I extended it a lot but :) & nbsp;
PCs were broken, let's connect to a pc next week and they said. >
in short serco05 & nbsp; many thanks & nbsp;
08.05.2020 17:16 # 16
tellotello
[QUOTE = msk_sansal] I went to the Authorized Service today and the problem was SOLVED. they didn't care about the air suction-thrust, there was no hose left, then they said that the air filter box's hose was loosened, they took care of it, I tried it, I said really thank goodness. As if there is a problem of drowning, it is more like a less drowning sound. When I have a problem, it seems like a drowning sound is going down to 3000 revolutions while it is at idle, it is also in gear, when it is under load .... in the same way when it drops to idling in idle and gear .. anyway & nbsp; 90% gone. .
PCs were broken, let's connect to a pc next week and they said. & nbsp;
in short serco05 & nbsp; thank you very much & nbsp;
it is obvious and it takes you to relax and link it on the computer & nbsp; .
Meanwhile, I know it is normal to burn a little bit after maintenance Do not worry, your puppy will soon be recovered & nbsp; "Smile".
08.05.2020 17:16 # 17
msk_sansal
I would say that the fuel will increase, the war has increased considerably.
