Dropped from 307 traction
08.05.2020 14:54 # 1
ramtas
Hello friends, I have an automatic 307 with 1.6 xt 2005 mode. Today I am hard on the road at 110 km speed. As the engine gives gas, it gives a strange sound. As the bidet gives gas to the car, it sounds like vooonn, but the car does not accelerate. The rampada fainted 90. it was hard
08.05.2020 14:54 # 2
The clutch busting pad needs to be finished finished
08.05.2020 14:54 # 3
BAHTIYAR
automatically, the press will not start the pad, as far as I know, if the car has a malfunction in the engine or the transmission, the car protects itself, does it break down on the screen as soon as the high speed
08.05.2020 14:54 # 4
ramtas
No, the vehicle does not signal a malfunction. The engine does not accelerate as the gas accelerates
08.05.2020 14:54 # 5
Onur
Does the contact turn on and off as if the gearbox malfunctioned? classic automatics become a torque convector triptronics have clutch & nbsp;
08.05.2020 14:54 # 6
BAHTIYAR
307s are not triptonic. >
08.05.2020 14:54 # 7
ramtas
No, it doesn't look like it's a problem from the engine
08.05.2020 14:54 # 8
BAHTIYAR
Everything we say without seeing the car is very accurate, there are a lot of possibilities. Do not use it, I think you should go to a service and learn the malfunction.
08.05.2020 14:54 # 9
Onur
show to a service, if it doesn't improve in my mind, something else can happen & nbsp;
08.05.2020 14:54 # 10
BAHTIYAR
By the way, I know that they have a greasy pad wv dsg transmission, life-long transmission, I know everyone who follows the auto magazines knows the pressure of the oil is going to be 307. Let's say it is wrong.
08.05.2020 14:54 # 11
Fahri
There is a problem with the gearbox of the car and it protects itself, as the bahatti says, saves and reduces power ....
08.05.2020 14:54 # 12
ramtas
I connected it to the device, it did not break down the transmission. How to detect if it protected itself
08.05.2020 14:54 # 13
BAHTIYAR
then there is no fault in the transmission, if you take it to the authorized service, if you make it to the land, if you do not get the fixing fee, if you do not get it, they get 100 lira fixing fee
& nbsp; meanwhile, when it comes to the press pad, I knew it right in the service, I asked the service & nbsp; There is one more system for me + there is a convector system that I call the trub / vehicle is not a trpitonic electronic transmission & nbsp; It is a shame not to learn not to learn not to learn to friends who know that there is a print lining on the automatic models of peugeot 308 and BIPER !!!!!
08.05.2020 14:54 # 14
ucyuzyedi
How did you solve the traction problem?
08.05.2020 14:54 # 15
karambol14
Check the air filters of the vehicle.
When we get p, a sound sounds like click & nbsp; it sounds like it is in progress. Is there a sign.
08.05.2020 14:54 # 16
ucyuzyedi
I checked the air filter. there is no warning sign like - * s on the screen.
08.05.2020 14:54 # 17
berk2309
If the teacher connects to the computer and looks at the pressure values, it will be obvious that if it comes out, it can be seen that the torque converter is on & nbsp; it can fall over time due to the fact that it is full of torque torque converter & nbsp;
