Driving in 2nd gear ..
08.05.2020 14:10 # 1
Have a nice day. I live in a quiet place, paved with cobblestones, where there are plenty of casists. I usually watch it without pressing the accelerator pedal in the city. Is there any harm to the vehicle?
08.05.2020 14:10 # 2
Sinan
I think your speed will decrease, but I think it would be better if you used it in 2000 gear in 1st gear.
08.05.2020 14:10 # 3
H-a-d-i
You'd better touch a little more gas in 2nd gear. It shouldn't be too dead.
08.05.2020 14:10 # 4
Sinan
Or, as our brother said, increase your speed a little more. Not to fall down from 2000 rpm. So the engine is choking. Sinan 2010-02-19 12:40:23
08.05.2020 14:10 # 5
F-Eren
Take your automatic gear, don't worry about them bro!
08.05.2020 14:10 # 6
firat.pj34
forever manual gear: D: D
08.05.2020 14:10 # 7
vbmaster
It burns a lot and my brother also does not have that strangulation sound :) If you are not nervous no problem pleasant driving ...
08.05.2020 14:10 # 8
There is no drowning sound ... I was just doing this in the flat area, but I don't do it anymore ... No need to experience hard work again with experience :)
Also, I don't like automatic gear. It gives the feeling that I am not using the car. gear
08.05.2020 14:10 # 9
kocvizyon
I think it would be better if you hit a bit more gas, sometimes I pay attention to my use.
08.05.2020 14:10 # 10
yzt06
Watching for a long time at low speeds such as 1000 cycles may cause problems in the future.
08.05.2020 14:10 # 11
F-Eren
[QUOTE = laedri] There is no drowning sound ... I was just doing this in the flat area, but I don't do it anymore ... No need to experience hard work again with experience :)
Using automatic means not taking two rounds with your friend, take a use automatically :)
Also automatic transmission has been proven worldwide. You don't have to worry about shifting gears, you're on your way, ok?
08.05.2020 14:10 # 12
BurcUMUL
[QUOTE = firat.pj34] forever manual gear: D: D [/ QUOTE]
+1 Alkış
08.05.2020 14:10 # 13
For those who see dealing with gears as a problem, of course auto. The gear is nice. But I don't see dealing with the gear as a problem.
08.05.2020 14:10 # 14
First of all, let me say that the automatic gear of the piano is not put on the door, 80 percent of it is malfunctioning, if your vehicle is diesel, you will break the turbo and the engine ears often fail and damage the flywheel.
If gasoline is not a problem, the car wants to aspire the gear, you understand that idling 2nd gear gear does not load the engine with gasoline 1.5 cm gear is bigger than the 1st gear gear but 3.4.5. gears are large speed gears, do not keep the clutch depressed and do not drive
