driver's side is getting water help
08.05.2020 17:43 # 1
alp2525
When I washed my 407 diesel vehicle, I saw that the driver's side was soaked, and the pollen filter was also not soaked when I removed it next to the driver's foot. I cleared the expenses on the side of the windshield & nbsp; & nbsp; where did the water enter last week.
08.05.2020 17:43 # 2
error
I think it's getting water from the windshield grille, it may be cracked or loose.
08.05.2020 17:43 # 3
alp2525
I do not know, brother, I just went to look at the car, I did not understand how it was getting so tight on the passenger side.
08.05.2020 17:43 # 4
alp2525
I have exchanged with murat from Şahinpeugeot. Did the grill necessarily change if it was made from the grill that had the same problem in a vehicle?
08.05.2020 17:43 # 5
ondercan
Under the windscreen grille of the vehicle there are water drain holes. I think they are clogged, when they get clogged, they are going through the valves there. I say look.
Good luck with..
08.05.2020 17:43 # 6
alp2525
If the holes under the grill you say are draining from the fenders located on the right and left, I cleaned the water and the water comes to the pipe coming directly to the pollen filter and flows from the right and left center console.
