driver door lock problem
08.05.2020 17:14 # 1
adali
My friends tool is very annoying and there is a problem we can't find out why. vehicle 307 1,4 diesel 2003 model. When the vehicle's driver's door is open, the doors can be locked and unlocked from the key control. normally this should not be locked or unlocked. it is not possible to close and open the key control when any of the other doors are open (normal). At the same time, I unlock the vehicle with the key control while all the doors of the vehicle are closed and locked. As soon as I open the door of the driver, it locks the other 3 doors. Whether I happen to be inside the vehicle or when I open the driver's door, it locks the other 3 doors. He doesn't know who I showed it to. I'm waiting for your help. Thanks in advance ....
08.05.2020 17:14 # 2
Serkan
The war is an interesting problem.
08.05.2020 17:14 # 3
adali
While all the doors of the vehicle are closed and locked, I unlock the remote control. interior light lamps are normally on. As soon as I open the driver's door, the overhead lights go out, 3 doors lock. I never paid attention to the middle screen
08.05.2020 17:14 # 4
Serkan
Sir, you started the car, all the doors are closed, when you open the driver's door, the inner headlamp is on, normally if the inner headlamp is in the door position, it should be lit, the car should beep, if these are not the sensor in the lock is defective and the car is considered to be closed.
08.05.2020 17:14 # 5
adali
I have come to try it now. I started the car, all the doors are closed, the top lamp did not light up, the door did not say open on the middle screen. I wonder if something like wd40 was bored on the doors.
08.05.2020 17:14 # 6
Serkan
The problem is that in the lock sensor, my teacher thinks the car is closed when the door is open.
08.05.2020 17:14 # 7
adali
okay teacher. My first job tomorrow will be to lubricate the lock. Should I use something like wd40 style or do you have any suggestions?
08.05.2020 17:14 # 8
Serkan
Hodja, I have gear oils that they use in our factory 1-2 times a year, but I do not know which is the healthiest, I know wd40 is more rust and dirt remover. Try a normal machine oil if you want.
08.05.2020 17:14 # 9
adali
Thanks, teacher, you have been very helpful
08.05.2020 17:14 # 10
Serkan
You are welcome, I hope the problem is solved easily. & Nbsp;
08.05.2020 17:14 # 11
atlasbm
It is interesting that the other 3 doors lock when the driver opens the door. If the driver sees the door closed, the driver should not give a warning on the middle screen when he opens the door, but how much effect does it have on other doors. I hope the solution will be easy and inexpensive. I would be glad if you inform about the result.
08.05.2020 17:14 # 12
adali
yes guys how many days i have been dealing and we solved the problem. the problem was in the front left door lock. the electrician checked the master and cut off the blue one among the thin wires leading to the door lock. In this way, when the driver opens the door, the other doors do not lock, but on the other hand, the top lamp does not light up and does not appear in the middle screen. this is a temporary solution for now. I will investigate the price of the door lock, maybe its quality may be out of crashed vehicles. & nbsp;
08.05.2020 17:14 # 13
pierson
When I open the car door, the interior lights are not on ... what could be the reason ... the lamps come on when you push the top buttons back and forth ...
08.05.2020 17:14 # 14
Serkan
[QUOTE = pierson] When I open the door of the car, the interior lights do not come on ... what could be the reason ... the lamps come on when you push the top buttons back and forth ...
08.05.2020 17:14 # 15
pierson
I tried serco is not lit ... when I put it in that position it is constantly lit ... same as the other position ...
08.05.2020 17:14 # 16
Serkan
Have you tried while the vehicle is running, when the vehicle's doors are opened for a certain period of time, when the ignition is plugged in and starts & nbsp; it turns off, if the vehicle is on after it starts, it may be a problem in one of the locks. > 2012-12-29 22:59:05
