drive airbag
08.05.2020 17:41 # 1
tongucuk
friends, I do not remember that a topic related to this issue has been opened before the driver the airbag light is on when I first start it in my car, it does not light up after 3 seconds, it turns on, a foreign text appears on the screen, I asked a few people, said it from the socket under the seat, who said steering wheel, said someone from com 2000, how do I solve it need
08.05.2020 17:41 # 2
sayginotp
You have to make a diagnosis first, whatever it takes to determine the defective location, it is mostly caused by the com2000 coil or the sockets under the seat.
08.05.2020 17:41 # 3
umut_25
I think one of the chronic problems is the master .... I suggest you check the socket under the seat. Compress if it does. The problem will disappear.
08.05.2020 17:41 # 4
Serkan
Sometime burned in me, the airbag fault is written on the screen, there is an airbag socket that enters the com2000 under the steering wheel, it loosened, I tightened it. When you remove the cover under the steering wheel, the sockets appear, if you want to check for a brown color, remove the sockets under the seat and clean it.
08.05.2020 17:41 # 5
tongucuk
Is there an illustrated explanation of the places to be removed from the draction and armpit, should I do something wrong?
08.05.2020 17:41 # 6
sayginotp
If the sister vehicle is 307, there is no socket under the seat, the belt system that explodes or protects it is located on the seat belt on the peugeot 307 models in the room center door pillars. The armpit socket system is available in partners, 106 and 306.
08.05.2020 17:41 # 7
Serkan
Dude, in the picture below, there are screws on the right side of the screwdriver and at the right level. You will pull the cover out.
After removing the cover, the sockets you see in the picture below will be attached to their places, and the brown socket I took in the red circle gave an airbag error because it was loose. Check all the sockets, take it back, plug it in, I hope it is as simple as mine in your problem.
I wrote the above message for another friend, I hope it worked for you.
If it is under the armpit, you will see it when you look down, if your car has a side airbag :)
08.05.2020 17:41 # 8
tongucuk
thank you manager for pictures only mine is 307 pictures 206 is the same side pillows have
08.05.2020 17:41 # 9
Serkan
[QUOTE = ramazanturan81] thank you manager for pictures only mine is 307 pictures 206 same pillows on side poles [/ QUOTE]
Same is the Ramadan com2000 (Headlight, signal, airbag unit) 307 out of me already :)
08.05.2020 17:41 # 10
tongucuk
Big smileClap
08.05.2020 17:41 # 11
baha1907
I have a partner, I have the same problem with me for about 2 months. the cables under the armpit are intact ... if I connect it to the service device, I will get 50 TL, I am still not waiting :) We think it is from the signal lever.
08.05.2020 17:41 # 12
tongucuk
never tied it down, don't waste money, I got it connected, it just says airbag malfunction.
