downshifting in automatic vehicles
08.05.2020 15:36 # 1
fTh206
While reading the nets today, I was reading an article while I was going downhill in automatic vehicles, but I wasn't going to waste N, I mean, I wasn't going to waste it, but what would the damage be? Frankly, I profit a lot from gasoline ...
08.05.2020 15:36 # 2
As far as I know, the automatic transmission does not make lubrication when it takes N beside the bos. For this reason, I wish it shouldn't be put on the board while on the move without the importance of having a ramp or flat ...
If our situation is valid in our automatic transmission, it is probably valid if you use it, so if you use it, you are likely to harm your transmission.
the cecol 2011-06-13 11:51:02
08.05.2020 15:36 # 3
fTh206
I've always been idle all this time, there has been no harm. Ağlama
08.05.2020 15:36 # 4
[QUOTE = fTh206] I have always been idle in idle all this time, there has been no harm Ağlama [/ QUOTE]
I would advise you not to continue the same behavior ...
08.05.2020 15:36 # 5
fTh206
I did not find the text on it very realistic, but when you say it, I should not damage the gearbox so that I would never buy it again and make profit from gasoline.
08.05.2020 15:36 # 6
motoberk
Yes, the transmission does not lubricate at that time. For example, it can be wasted when lights are stopped or if more than 20 seconds of pause is required. This ensures oil circulation and the shift from position D at the time of pause does not force the car.
08.05.2020 15:36 # 7
volkan_uysal
If you go downhill with friends, the vehicle will burn fuel as it continues to idle, if you get off, it does not burn, at least instant fuel consumption shows 0
08.05.2020 15:36 # 8
only_younus
[QUOTE = volkan_uysal] If you put your friends downhill, the car will continue to run at idle, it will burn fuel, if you get off, it will not burn at least instant fuel consumption shows 0 [/ QUOTE]
However, the fact that it is in gear has a slowing effect.If you look at it as efficiency, it is more efficient to watch it idle.It is only harmful if this efficiency is doing revolution elsewhere.)
08.05.2020 15:36 # 9
Selim Engin EREN
is not wasted except for pauses.
08.05.2020 15:36 # 10
ilkertuncay
Friends are not wasted when a car is going downhill, there is nothing to burn when it is wasted.
08.05.2020 15:36 # 11
fTh206
[QUOTE = ezelefe] I couldn't remember where there was ole yokus while going to yalova)))
I'm too tickling when I come home
[/ QUOTE] pear road 20 km uphill I will go again next week I put the pictures on the site
08.05.2020 15:36 # 12
metin
If you throw fth206 wasted accident, you have to stop the vehicle before taking D, otherwise you may cause serious damage. You may be as if you are waiting in the lights because there will be no lubrication while idle, you are right, not less than 20 km uphill. I don't think that if you stop and put it in gear before putting it into gear, I don't think it will be a problem, because the profit you make can come back to you as disc brake, etc., because you will brake continuously.
08.05.2020 15:36 # 13
fTh206
[QUOTE = text]
[/ QUOTE] No, I don't buy n any more, don't let the eye come out while browsing Sırıtma After all, we use the automatic vehicle, they fold the rose-loving thorn, let's go from the gas. Sırıtma
08.05.2020 15:36 # 14
fTh206
[QUOTE = ezelefe] I thought you were going to Istanbul from Yalova.
I can not leave the pear road if you call it from the edge of the sea or the bursa road.
[/ QUOTE] no, we are going to yalovaya kdr sea bus in istanbul after you know you already know çınarcık esenköy armut always uphill you are right i did not explain there is not much slope
08.05.2020 15:36 # 15
metin
[QUOTE = fTh206] [QUOTE = text]
It doesn't matter much. I already did two months ago in istanbul - denizli - burdur - istanbul.
08.05.2020 15:36 # 16
monur
[QUOTE = fTh206] I have read an article on the net while walking around the curse today, it was definitely going downhill in automatic vehicles. down, so I always waste it, I actually profit a lot from gasoline ...
How many years have you been driving professionally?
08.05.2020 15:36 # 17
Selim Engin EREN
[QUOTE = ilkertuncay]
Alkış
08.05.2020 15:36 # 18
F-Eren
[QUOTE = CeCoLi] As far as I know, the automatic transmission does not make lubrication when it comes to N beside it. For this reason, I wish it shouldn't be put on the board while on the move without the importance of having a ramp or flat ...
does not lubricate exactly and seriously damages the gear.
Do not waste while walking can only be taken while the vehicle is stationary. Waiting for more than 30 seconds
08.05.2020 15:36 # 19
statistican
Do not waste your time on ramp landings, friends are not only risky in terms of braking and fuel consumption as expected, 4-5 horse's gear is nice. the statistic 2011-06-13 17:31:54
08.05.2020 15:36 # 20
sole let me answer myself manual yokus assaga no hic time I do not throw it to the bosphorus continuous bosta continuous braked because it is relieved, the temperature of the leak is high according to the flow, the flow continues, because the bosta vehicle continues to consume fuel, the vehicle cuts in the vice, if you say auto vending vehicle I do not take it because it is obvious that it may cause problems in my mind after that, but I have not lived until this day, but there is a risk of being and my brother does not approve of the mechanic at the subaru service. Gülme our ahmetsk 2011-06-14 00:00:52
Page : / 2
