Double tape assembly aid |
| 08.05.2020 21:12 | # 1 |
| 08.05.2020 21:12 | # 2 |
I'm asking someone who can help, who knows anyone? |
| 08.05.2020 21:12 | # 3 |
Alicilik |
Sockets must work when you plug in a compatible pole. rd3 and in the sema you sent 4 number battery (memory) Contact number 7 Number 8 sase it looks the same. If it is different, connect these cables of the corresponding socket in your hand properly. Change the green of 4 to 7. Do not reach for him when the joystick does not work |
| 08.05.2020 21:12 | # 4 |
[QUOTE = Receiving] Sockets must work when you plug in a compatible pole. rd3 and in the sema you sent 4 number battery (memory) Contact number 7 Number 8 sase it looks the same. If it is different, connect these cables of the corresponding socket in your hand properly. Change the green of 4 to 7. Do not reach for him when the joystick does not work Like the same but there is a difference, so the memory is not permanent, it goes off and it goes urgently. I think there is a steering wheel control in the frequency of the clock.
| 08.05.2020 21:12 | # 5 |
So, in the picture below that I have with rb3, for example, what is van data, how do I have to synchronize the tape without trying to connect the camera without interrupting the two, for example, the red one tried to connect to the camera, the tape worked normally.
| 08.05.2020 21:12 | # 6 |
You had to buy a special apparatus for the control lever to work. the price of this is around 200 TL. I say it is not worth.
| 08.05.2020 21:12 | # 7 |
sonerkyl |
there is no need for me serkan 200 TL is a small apparatus
| 08.05.2020 21:12 | # 8 |
I made the car later: -205/55/16 rim tire -zone headlight -american park -cam movies -parking sensor -double tape -back camera -cruise control I think there is nothing else :)
| 08.05.2020 21:12 | # 9 |
I was never tired, I removed the tape and looked at the connections, teacher, I had a hard time connecting it. The red cable from the tape will be connected to the green yellow cable next to the large size yellow green cable. The yellow cable from the tape will be connected to the dark gray cable. The black cable from the tape will be connected to a large yellow green cable. I hope I was able to explain, I can not add photos since I logged in from the phone, sorry. When connecting, do not cut the original socket and cables, teacher, peel off with mock-up.
| 08.05.2020 21:12 | # 10 |
friends I bought from this tape. I got the electrician There is no memory problem, I close the tape with my hand, but due to the feature of the tape, the screen light remains on. It says hours in the middle. This is how it closes. Will the battery drain or something because the screen light remains on?
| 08.05.2020 21:12 | # 11 |
Good Ramadan friends, I have been talking about the issue, but I am writing it as a solution to the need. I bought it from the 7785 device I mentioned, I connected it directly to the camera. the screen light remained on the clock and the car was reset to memory memory after a certain period of time. I will probably find a solution with a1 a2 a3 one of them. As a result, for sukru38 and lilokan friends, my solution is to draw a line from yellow to the line. (I'm sorry for spelling and spelling errors)
