Double tape
08.05.2020 20:19 # 1
savran03
Hello friends 2003 model 307
I am thinking of installing double tapes on my vehicle. I want help from those who have experience in this matter. How many inches are suitable. Does the brand notice. In addition, when the original tape was removed, the trip computer screen was canceled. Thank you from now.
08.05.2020 20:19 # 2
TugyyStyle
There are original-looking tapes for the 307, I recommend it.
08.05.2020 20:19 # 3
ggitaristt
You said double tape. Already the dimensions are standard .. Get 307 or old case 308 compatible joystick menu or something works ..
Note: In 2003 307, the screen has nothing to do with the tape !?
08.05.2020 20:19 # 4
savran03
thank you friends
08.05.2020 20:19 # 5
drntgl
Hello there,
I bought a 307 XR 2003 model about 2 months ago.
Cyclone branded double tape recorder is about 750 TL. The clip was not playing, I was able to upload clips in avi format with converter programs from the internet. MP3, rear view camera and navigation work smoothly. The radio menu is very functional and the interface is nice BUT;
1. The radio does not work even though the antenna is renewed, it does not sow in most places, it is scratchy when it is pulled.
2. The navigation keyboard is very bad, you can hardly type the address. After typing the address and all the rest of the menus are great.
3. The bottom and top touch keys of the screen are sometimes hard to detect.
4. Every time the car is turned off and on, all the settings and the function you run return to the beginning, no cache. For example, the Clip does not restart when you are in the folder you are running or from the folder where you are playing mp3. you have to choose music from folders again. does not continue where it left off.
I would say that the average of Double Din tapes around 1000-1200 do not look cheaper anyway.
Good luck, good luck.
08.05.2020 20:19 # 6
drntgl
The model in me is very similar to the model in the link below.
My advice is to take the volume up key from round dial types.
08.05.2020 20:19 # 7
maximusti
Personally, I do not like double tapes, of course, afterwards.
but there is a brand called avgo, research it, with the original remote, etc. it fits perfectly.
I maximus 2017-05-05 22:21:46
08.05.2020 20:19 # 8
ahmetemir
[QUOTE = drntgl] Hi,
I can only answer to the 4th option, I bought 1,500 TL, I am very pleased, I installed it myself, the same thing happened. I also watched the radio channels that you recorded on the clock was reset, I searched and solved the problem now. There is no need to plug the needle into the socket, remove the pin, replace it and insert it, you will see that the problem is solved.
