Double din subwoofer output not working
08.05.2020 19:19 # 1
OnuR67
Hello
I installed Navitech dtv8500 multimedia system and reversing camera on my 307sw vehicle. Everything is fine, but when I connect a sub to the subwoofer output on the back of the tape, I cannot hear sound. Even though I made the sub on-of position on the menu of the tape, it did not work, the sound of the subwoofer was tested.
Does anyone know about this or is the device malfunctioning?
08.05.2020 19:19 # 2
OnuR67
I found the answer to my question, I am writing for those who are curious.
The current SUB outputs send the amp signal, so the amp is not working when we connect the SUB directly.
08.05.2020 19:19 # 3
Alicilik
RCA Pre-OUTs are all signal outputs. Cannot be connected directly to the speaker. Well, you haven't burned the exit. I do not know if there is a tape that will operate the six amps.
08.05.2020 19:19 # 4
OnuR67
[QUOTE = Receiver] All RCA Pre-OUTs are signal output. Cannot be connected directly to the speaker. Well, you haven't burned the exit. I do not know if there is a tape that will operate the six amps.
I had some luck, it was not burnt, I interpreted that they made an output that can directly connect the sub output :)
