"Double Din Multimedia"
08.05.2020 20:55 # 1
Ertanbur
Can "7 inch Double Din Multimedia" be inserted into the slots of the CD changer and CD player in the 307s? Or can it be applied where the trip computer is? I have seen this done on a number of international websites, but I do not know the details and details. The screen is not working anymore ...
Note: I could not find the Turkish equivalent of the English terms I wrote in quotation marks.
08.05.2020 20:55 # 2
Ahmet Bektas
Navitech brand is attached to the 207s, the remote control works on the arm, but it is necessary to investigate whether it is attached to the 307s.
08.05.2020 20:55 # 3
maximusti
You can disassemble the original tape and cd changer in 307s and use the tape with the appropriate frame.
But in some 307s, the trip computer does not work when it is removed.
In Turkish, "double religion" :) is a Turkish word now
08.05.2020 20:55 # 4
Gokcesel
Yes, you can remove the CD and changer. If the steering wheel and your display are type C, you cannot adjust the information of the screen, the original tape is required for it.
RT 3 system in Turkey and abroad are rare for the 307, the multimedia trip computer display screen hangs there.
08.05.2020 20:55 # 5
Ertanbur
[QUOTE = maximusti] In 307s, you can disassemble the original tape and cd changer, and use the right tape with the appropriate frame.
Thank you very much for the information you provided. As I said, the trip computer screen is faded even though it doesn't work anyway. However, if the trip computer fails when the trip computer is down, it would be pointless to install it. Shouldn't be doing "double axle", right :)
08.05.2020 20:55 # 6
Ertanbur
[QUOTE = Gokceel] Yes, you can remove the CD and changer. If the steering wheel and your display are type C, you cannot adjust the information of the screen, the original tape is required for it.
Thank you very much for the information you provided. I do not know the type of steering wheel control and screen. It doesn't matter, I can't use it anyway. The friend I bought the car disassembled the CD changer and replaced a mini-screen tape recorder, connected the rear view camera to it, but does not memorize the radios, it resets itself when the ignition is switched on and off. So it's useless.
08.05.2020 20:55 # 7
maximusti
[QUOTE = Ertanbur] [QUOTE = Gokceel] Yes, you can remove the CD and changer. If the steering wheel and your display are type C, you cannot adjust the information of the screen, the original tape is required for it.
Thank you very much for the information you provided. I do not know the type of steering wheel control and screen. It doesn't matter, I can't use it anyway. The friend I bought the car disassembled the CD changer and replaced a mini-screen tape recorder, connected the rear view camera to it, but does not memorize the radios, it resets itself when the ignition is switched on and off. So it's useless. [/ QUOTE]
The radio memory event has a five-minute job, pull out the tape, swap the yellow and red cables, and the problem is solved.
I try it that way and decide after that.
You can use the steering control if you get the double din tacks that are oem-enabled.
If you are not using the trip computer, you will not have any problems.
08.05.2020 20:55 # 8
Ertanbur
[QUOTE = maximusti] [QUOTE = Ertanbur] [QUOTE = Gokceel] Yes, you can remove the CD and changer. If the steering wheel and your display are type C, you cannot adjust the information of the screen, the original tape is required for it.
Thank you very much for enlightening me with the detailed information you provided. First, I will move the cables. If I get a positive result, I use it this way. Don't be missing. I wish accident-free driving.
