Doors locked when the vehicle moves
08.05.2020 20:14 # 1
x571
Hi
2002 Is it possible to lock the doors automatically when the car moves for 306 platinum. Once the doors are locked, they can only be opened from the inside and not from the outside.
08.05.2020 20:14 # 2
I do not think I have never heard of it in 306, teacher.
08.05.2020 20:14 # 3
selcuk3641
When the door lock button inside is pressed for a certain period of time, it has to be activated automatically and it gives a warning on the vehicle screen because the vehicle locking system is active. selcuk3641 2017-03-14 15:56:55
08.05.2020 20:14 # 4
x571
[QUOTE = selcuk3641] When the door lock button inside is pressed for a certain period of time, it has to be activated automatically and it gives warning on the vehicle screen, the vehicle locking system is active.
Which button inside is the pin on the door or the lock knob on the key
08.05.2020 20:14 # 5
x571
[QUOTE = sonerkyl] I don't have it in the 306s, I don't think if I have never heard of it. [/ QUOTE]
If I install a lock system other than the original lock system, can it win?
08.05.2020 20:14 # 6
ggitaristt
Install a Chinese alarm, while the car is running, the doors are locked at the first touch.
08.05.2020 20:14 # 7
x571
[QUOTE = ggitaristt] Alarm made in China, when the car is running, the doors are locked on the first touch of the brake. Take the one with the automatic trunk key, you can open trunk from the remote control (direct pressure to open)
Whether it is a feature of the alarm Smile
08.05.2020 20:14 # 8
Ege Mavisi 206
When you hold the door lock button next to the four flasher button for 4-5 seconds in my 206, the automatic lock you mentioned is activated with an audible warning. When it reaches 10 km / h, the door locks. If I don't press the same button from the inside or try to open the door normally, it doesn't open from the outside. When turning off the system, the system shuts down with an audible warning by pressing and holding that door lock button for 4-5 seconds next to the flasher button.
I don't know if your car has this hardware, but that button it says.
08.05.2020 20:14 # 9
ggitaristt
[QUOTE = x571]
Feature yahu Big smile I had done it to my Şahin vehicle 10 years ago, he would lift the trunk with the remote control .. He would lock his doors himself .. The immobilizer feature had come. With 50 lira alarm set Wink
08.05.2020 20:14 # 10
BLACK LION
If there is a key to lock the doors from the inside, if you hold a sound like click and wait, it is activated. It is locked after 20 km. Otherwise there is no =)
08.05.2020 20:14 # 11
x571
[QUOTE = BLACK LION] If there is a key to lock the doors inside, if you hold a sound like click and wait, it is activated. It is locked after 20 km. Otherwise there is no =)
Unfortunately, there is no such button. You have to get that feature with an alternative method. I don't know if that will damage the vehicle.
