Door wick solution (Pictorial)
Homepage » PEUGEOT MODIFIED PLATFORM » General
08.05.2020 15:18 # 1
motoberk
Over time, the door seals in the vehicle's frame deform. These deformations can be in the form of surface wear, flattening, tearing. If there is no tearing in the wick of your vehicle, I recommend you to try the application I will tell. The difference is understood, at least when the door is closing, a loud voice is heard. Göz Kırpma
The purpose of this application is to pass a soft material that does not make much thickness without removing the existing wick. You can try different alternative materials according to your preference and deformation of your existing wick.
I first tried this hose. But even though it was very soft, it came thick, the door closed hard and opened hard, it was a 10 mm hose. Maybe the 8mm one can be complete.
Let's come to our application, we cut the wick of the door you will make from 3mm right and left of the joint. We insert our material into the part we cut and push it. To give slippery here, soapy water etc. you can use the substance. You can also make a guide with a wire.
Since the wick itself was oily because I was not able to do it, I could pass the wick up to the door top turns. In the remaining sections, I cut a section at the top. Ağlama
The wick I use is a wick that you can find in aluminum joinery workshops. It is available in different types. I tried with this because this is near me. There are also round ones. Since the purpose is to fill the existing wick, there is not much problem.
I will make this application in the luggage in the near future, if it is positive, I will inform him.
Hopefully it benefits your business.
08.05.2020 15:18 # 2
motoberk
By the way, I did not write the cost. Get a wick. 10mt in the joinery workshop. You can buy it at a very small price.
08.05.2020 15:18 # 3
only_younus
Is there a problem with the photos, I can not see
08.05.2020 15:18 # 4
motoberk
[QUOTE = only_younus] Is there a problem with the photos, I can't see [/ QUOTE]
I added the picture for the first time my teacher, but I don't know. It seems to me, or does it seem to me because this is made from the computer.
Anybody can see the pictures?
08.05.2020 15:18 # 5
F-Eren
there are pictures you have thought you thought good health :)
clicking here If you become a member of imageshack (free), you can easily see the pictures ok?
08.05.2020 15:18 # 6
Muhammet CAKIR
In the hands of my brother, I have a good idea :) but I could not understand the wick: I look small in the D pictures, I give the eror when I see it, I can not
08.05.2020 15:18 # 7
Serhun
Thank you for sharing.
08.05.2020 15:18 # 8
goktug
successful application congratulations ,,,
08.05.2020 15:18 # 9
Not bad, actually :))
unwrapped, not torn, but crushed films can be applied for.
08.05.2020 15:18 # 10
metin
both cuts the sound and shuts down, it is good
08.05.2020 15:18 # 11
motoberk
[QUOTE = Muhammet ÇAKIR] I have a good health sister in my hand :) but I could not understand the wick: I look small in D pictures, I can not give eror during the time [/ QUOTE]
As I mentioned, Mr. Muhammet ÇAKIR, the type of wick does not matter. As dwg I couldn't find the wick that I used, I found this, because this wick is more round, I think it gives full results.
Uploaded with ImageShack.us
Dimensions are in mm.
08.05.2020 15:18 # 12
only_younus
[QUOTE = fearmutlu] it seems there are pictures you thought good health :)
I already have a membership in imageshack, but I still cannot see :(
08.05.2020 15:18 # 13
Haksen016
Thank you for your health information.
08.05.2020 15:18 # 14
hasansinayan
Does anyone know an affordable price place in Ankara, the prices for this wick are flying in the market. Or is there any other application such as installing a steel door wick.
08.05.2020 15:18 # 15
emin08
I have read elsewhere that they do this application with air hoses used in aquariums. I think he will do the same. The cost is also very low.
08.05.2020 15:18 # 16
sedataksu
Congratulations, good idea. You can find the material in places selling furniture, the mistress needs to be under 1 TL.
08.05.2020 15:18 # 17
The work is nice, but the clip-like black bar on the door trims for the car mount is broken. How can we handle this?
08.05.2020 15:18 # 18
sole answer I recently got a guaranteed service at the service.
08.05.2020 15:18 # 19
emre_65
friends, I think the subject is hortlatacam: D is the most suitable and solid material for this job, we all had a bird sling when we were children. I hope the yellowish elastic is enough: D
08.05.2020 15:18 # 20
emre_65
I know it's not hard to find, so to speak, there are lots of nyloners
Page : / 2
