Door Upholstery Removal And Speaker Replacement ..
08.05.2020 20:06 # 1
Peugeot35
I will answer the question of how do I remove the door trim and change the speakers on the door.I did not hear sound from the left rear door speaker and I thought it was broken, so I ordered the peugeot 307 original left rear speaker from the internet and came to my hand the next day. WE HAVE FULL STAR SCREW REMOVE THAT. KEEP THAT THIS PICTURE WHERE THERE THE NAIL BREAKED THE FRAME LEFT LIKE THE 7-NAILS. WE REMOVE THE SOCKET OF THE GLASS LIFTING MODULE FROM THE FRAMEWORK. CONCLUSION DOOR FLOOR IS IN OUR HAND. BECAUSE OUR SPEAKER IS NOT WORKING. WE ARE INSTALLING OUR NEW CLIPS AFTER THE INSTALLATION. IT HAS COME TO FITTING THE ORDER. WHEN WE TAKE THE FLOOR, WE PLACE THE SPEAKER'S SOCKET. WHEN I PRESS THE FRAME, I WILL BE INSTALLED AND THE FIRST REMOVAL OF THE SCREWS IN THE SCREWS ARE UNDERSTAND.
08.05.2020 20:06 # 2
OguzhanKucuk61
Nice work, thanks for sharing :)
08.05.2020 20:06 # 3
dejawu1978
good work Wink
08.05.2020 20:06 # 4
fkundak
God bless you, halal.
By ordering yourself a meal, my teacher would take 100TL or more of work outside, and they would definitely do it with worse workmanship.
08.05.2020 20:06 # 5
Gokcesel
Your health teacher. If you tried and plugged a higher quality speaker, at least it was worth your effort :)
08.05.2020 20:06 # 6
Peugeot35
[QUOTE = Gokceel] Good health teacher. If you were trying to plug in a better quality speaker, at least it was worth your effort :) [/ QUOTE]
Hodja, I have an original obsession, so it makes more sense to wear a good one. It is enough for me.
08.05.2020 20:06 # 7
Peugeot35
[QUOTE = fkundak] Thank God, halal.
By ordering yourself a meal, my teacher, they would get 100 TL or more workmanship outside, and they would definitely do it with worse workmanship. [/ QUOTE]
I ordered it, my teacher :) you are right, I asked you, I said we can get it out for 70 TL, I said I will get it for free :)
Peugeot35 2016-12-24 21:30:25
08.05.2020 20:06 # 8
muratsandalci
Many thanks for the info. As the speaker depth, how much does the environment allow?
08.05.2020 20:06 # 9
ben_erhan
Did you connect the speaker, teacher :) I couldn't see it in the photos. You just put it in place ..
best wishes. Good job. You have to be blind. At most 2 quotes are broken, but work is learned.
08.05.2020 20:06 # 10
Peugeot35
[QUOTE = muratsandalci] Thank you very much for the information. As the speaker depth, how much does the environment allow?
There is not much depth, but you can make up all brands. If you have added legs, the procedure is complete. but they all sit comfortably without the need.
08.05.2020 20:06 # 11
Peugeot35
[QUOTE = ben_erhan] Did you connect the speaker, teacher :) I couldn't see it in the photos. You just put it in place ..
The speaker has a socket. There is no possibility to install it incorrectly. It is the same as the glass lifting module socket. When I made the flooring with both hands, I know that I could not shoot it in writing. When you dock the floor to the door, you insert the speaker plug and at the same time you shake the glass lifting module plug from the frame and snap the floor. A little bit of courage just :)
