Door tiles replacement!
Homepage » PEUGEOT MODIFIED PLATFORM » 306
08.05.2020 18:36 # 1
TayfurKara
Hello dear friends. The original flooring on my car's doors sagged like most vehicles and completed its life. They had not been in my eyes until now, but after a vehicle with a leather upholstery that I got on recently, it started to bother me. I started to think if I could make a leather upholstery. "I consulted a master who made the auto glass film," he said. And we got to work. Let me know that it took 5.5 hours. Do not worry that I will tell you about the processes in full. Since the front doors are a bit more difficult, you will be more susceptible with the back door. Initially, you should remove the parts of the door that have plastic and upholstery. In other words, the door of your vehicle should remain as follows: Then you should separate the plastic part and the part where the flooring is. But this part is a bit troublesome. Unfortunately, since we have doors that are joined by melt the plastic, not the screws, you should separate the heating gun and the plastic screws by applying force up and down on one side. See: You need to easily remove the fabric that has drooped or you want to change from the upholstery. Then, in order to stick the fabric in the part you disassemble, you need to be cleaned from the adhesive surface used by the factory. You can do this by applying thinner to a cloth and digging it up. All the upholstery doors should be clean like here. Then, you should bring the leather or fabric (I chose black leather, I recommend it to you) to the size to be trimmed by leaving 2 cm more than the fabrics you removed. Do not be afraid to leave a surplus. The next process requires you to work in a sunny weather. You should apply the bali to seventeen to the surfaces you clean with thinner. But there should never be gritty remains. You can drive with a brush, for example. At the same time, you should feed the honey in the same way to the side of your skin or the fabric that will stick. Then put these two parts in a place where the sun is clear and leave for 7-10 minutes. Of course, you can do this process with a heating gun, but it is only the sun's job to give the same temperature to everywhere. After waiting for enough time, it is time to stick the floor. It is easier for two people to stick the flooring. Because there should be no wrinkles, air bubbles. Of course, this part requires talent. Remember that I had a master with me. After the adhesion process is finished, cut the perforated parts for the connection with the plastic part, the part with the door opening and closing module, the part where the door locking bar is ready to be installed. Then match the holes of the plastic part and the floor part and melt them with a heat gun until you believe it is strong. You can use it in silicone, but the process will extend to the next day as it dries. After the two parts are combined, it should be like in the picture. Plug and play operations are not difficult. I guess you can. Here is the state of the previous and next door upholstery of my vehicle: Before and After NOTE: - Never rush while doing the operation. You can have it between 150-200 TL. And make sure your car will look perfect. Here is the interior of my car: Best regards, see you. Tayfur Kara | www.tayfurkara.org Griffe, 306 1999
08.05.2020 18:36 # 2
Serkan
Good luck, my teacher is very nice, I guess it's like he needs it at the wheel :) Thanks for sharing.
08.05.2020 18:36 # 3
TayfurKara
I have experienced the necessity of change that you feel and I took care of that, teacher. :D
Thanks you for your precious comment...
08.05.2020 18:36 # 4
outlaw
HEALTH TO YOUR HANDS HAS BEEN VERY NICE ...
HERE IS THE DEATH OF THE DEEP ...
08.05.2020 18:36 # 5
Serkan
The steering parts of the steering wheel could pass under the airbag, in fact, it was still beautiful. Thumbs Up
08.05.2020 18:36 # 6
65serdal58
how do I make the same issue from the forum in my hands health.I have already provided the answer to my questions :)
08.05.2020 18:36 # 7
samet206
Good job, good bye :)
08.05.2020 18:36 # 8
rahmi 206
It is very nice, not worth the evil eye. Actually, my car needs such a work for a long time but I could not find any opportunity. Since the door side trims are not leather, there are abrasions and tears in place.
08.05.2020 18:36 # 9
barishrocker
Health in your hand, the doors are reborn. Also thanks for the detailed explanation;)
