Door Tension Pin ..
08.05.2020 16:40 # 1
Griffe
Hello ...
Tension pins (I do not know the full name) makes the sound when the right and left front doors are fully opened. ..? pin..? can be found ..? Also, when I pull the pin out, does the tensioner escape into the door ..?
Thanks ..
TIA ..
08.05.2020 16:40 # 2
werty
If walla has become that, it is not more prosperous. I advise you to change the complete tensioner. The tensioner price
is around 50 TL. Good luck.
& nbsp;
08.05.2020 16:40 # 3
Griffe
If [QUOTE = werty] walla has become that, it will not prosper. I advise you to change the complete tensioner. The tensioner price
is around 50 TL. Consult our sponsor. Good luck.
& nbsp;
I understand .. I want to disassemble the pin and try the screw. ..Good work ...
08.05.2020 16:40 # 4
GiTaRRa
no hinge o?
08.05.2020 16:40 # 5
dukenukem82
30-35 TL I had it installed 3-4 months ago, the left door, all the doors want, who is going to deal with, very hard doors .206 is a chronic problem, the door hinges are quickly broken, they make sound and hard to open and close.
08.05.2020 16:40 # 6
safrane23
I have the same problem, too. & nbsp; I didn't have the time to think that every time I opened the vehicle and the driver door, the same voice would handle an intermediate lathe. I looked at the address from Hepsipejo 52 TL original unstable.
safrane23 2012-03-30 10:16:40
08.05.2020 16:40 # 7
safrane23
