Door speaker aid suitable for 307.
08.05.2020 17:08 # 1
rataylan
Hello friends,
I am waiting for your help on the type of output power on my vehicle and the most suitable speakers I can attach to the doors. & Nbsp;
I have researched the insulation to be made inside the doors, I want to change the problematic speakers before insulation.
08.05.2020 17:08 # 2
hsnsnl
if you are going to change it, it is complete, otherwise it is not very useful.
08.05.2020 17:08 # 3
ahmetismet
I'm stuck on the white buttons of the tape. Is it the original?
08.05.2020 17:08 # 4
Alicilik
[QUOTE = ahmetismet] I'm stuck on the white buttons of the tape yaw. Is it the original one? [/ QUOTE]
In 2006-2007 and 207, such a teacher
08.05.2020 17:08 # 5
rataylan
[QUOTE = 307 bursa] If you are going to use the original tape, if the replacement is out of order, the originals give quality sound. >
Jbl etc. If you buy it, do you think there will be no difference in quality, do I buy the originals of Peugeot and put them on?
08.05.2020 17:08 # 6
rataylan
friends, I will buy the devices in the link for the front doors, if there is no other suggestion or warning,
http://www.hepsiburada.com/liste/kenwood-kfc-1664s-16-cm -3-way-200w-speaker / productdetails.aspx? ProductID = otcagkfc1664s & amp; # visuals CategoryID = 26090
08.05.2020 17:08 # 7
tolga35
I bought a 13 cm coaxial speaker behind the home roadstar
I think it was 30 TL. I understand that it will change. Next
there are now I will get the price of 16cm 41tl in a free time ...
note: if the originals are clean, I can sell them
"Smile"
tolga35 2012-11-19 19: 12:48
08.05.2020 17:08 # 8
efsanemurat
I have an eruption in front, in the back, what are these, and how can I get it in cm? I forgot the name of the bidet.
08.05.2020 17:08 # 9
This is called coaxial speaker. So it works without amphitheater. The front doors have 16 cm and the back doors have 13 cm diameter. The front chest is tweeted, so it gives high pitched sound. You don't need to change them. This means that no matter how high the speaker you will receive, it will not work efficiently. Each door should go at least 50w.
08.05.2020 17:08 # 10
Sahinozgul
I would like to change the dimensions in 308 for the same 308. I am obviously anybody with a small amp and sub suggesting that I will change all the speakers. Thank you.
08.05.2020 17:08 # 11
rataylan
[QUOTE = laedri] These are called coaxial speakers. So it works without amphitheater. The front doors are 16 cm in diameter and the back doors are 13 cm in diameter. It sends 30w audio output, which means that the speaker you get will not work efficiently, no matter how quality it is. Each door should go at least 50w. [/ QUOTE]
primarily thanks for the answer,
replacing the existing tape (steering wheel control, tire pressure, park, bluetooth etc.) is there a device that I can continue using all the features?
Reviews
Reviews
