"" Door Sound Insulation (With Solution) "" pictures page 2
08.05.2020 15:50 # 1
friends eventually I started the event that I had planned to do for a long time.
The definitive solution to the sounds coming from the doors is called .. You have read in some places sound insulation so that I applied the same application in my own car with the same methods ..
the result is excellent !! Does it work yes!
I will tell you the application here and I will give you a picture after tomorrow's operation .. I will write the materials I use for now.
I could only finish the left front door today, it took an average of 3.5 hours, but it was worth it .. even the door closing sound of the vehicle has really changed.
firstly i will share a little information about the materials i use
1. Our material
BTM BITUSELF
price: 10mt length 20cm width 50 tl (my purchase )
First of all, let me make the features of our famous btm bitüself material in an attractive way.
BTM is one of the leading companies in the insulation sector in Turkey has to offer BİTÜSELF Inc.
offers practical repair solutions in waterproofing with the product. Bitüself, 10-15-20-30-60 cm
by being used in widths and 10 m long rolls; practical, cold applied, self
It is an adhesive, bitumen based waterproofing tape.
I used industrial blow dryer while applying it, it becomes easier and stronger to warm up and stick
Features;
- Width: 10-15-20-30-60 cm
- Length: 10 m long roll tape
- Thickness: 1.5mm Thick
- Top coating: AL Foil
- Bottom Coating: PE Foil
- Temperature Range: -20 C / + 90 C
- Weight: 1m2 <1.5 kg
2. Our material
I bought ThermaFlex silent sponge meter for 7 TL
however, there are materials you will need to keep with you
rechargeable screw kit
scissors
falcate
silicon (transparent) silicon gun
industrial blower or tube and smooth
Segments for vehicle upholstery (new forehead is breaking) 7 pieces are sufficient for each door
I will share it with you under this topic tomorrow evening with the picture, the smallest practices and the way of implementation.
respects
the pugt 2011-07-17 19:51:23
08.05.2020 15:50 # 2
no picture buddy :)
08.05.2020 15:50 # 3
metin
I think I will do it myself. My goal is to insulate the door inner sheet as well for the sound system. I think isolation to reduce both the sound system isolation and the sound coming from the outside while doing
Meanwhile, the pictures are not visible, you must reload them.
08.05.2020 15:50 # 4
pictures tomorrow
08.05.2020 15:50 # 5
[QUOTE = text] I think I will do it myself. My goal is to insulate the door inner sheet as well for the sound system. I think isolation to reduce both the sound system isolation and the sound coming from the outside while doing
Don't worry, man, I did the inner hair of the door, my illustrated narrator, the important thing here is the inner hair. Göz Kırpma
08.05.2020 15:50 # 6
F-Eren
Let's see, I will do it in a wide time, I opened the subject recently, I did under the floor, not the inner sheet :)
I can say that we used the same materials.
I guess how many of the bits have you spent two are enough ???
08.05.2020 15:50 # 7
Come on, let's come easy, brother Kenan ... Let's see the water pictures tomorrow :))
08.05.2020 15:50 # 8
thanks friends
I think I bought 1 10mt 20 cm, I will start other doors tomorrow. Thumbs Up
I will do the back elbows in the next days and share them here
respects
08.05.2020 15:50 # 9
dinoco
How is Kenan available from? Thank you.
08.05.2020 15:50 # 10
Nice work. I look forward to the pictures.
08.05.2020 15:50 # 11
metin
[QUOTE = pugti] [QUOTE = text] I think I will do it myself. My goal is to insulate the door inner sheet as well for the sound system. I think isolation to reduce both the sound system isolation and the sound coming from the outside while doing
I did not mean the pugti application pictures. In the explanation on the subject, you put the bituself with the sponge, they do not open, I mentioned it. seems now but.
I follow the subject closely. You will get a little tired to understand for anyone who does not know my request, but I would appreciate it if you explain it in fine detail.
thanks in advance.
I have an important question and it gets stuck in my head. Is there a problem such as damage to the paint on the door of the vehicle as a result of warming on the inner sheet of the door when you stick it to the inner sheet of the door when it heats with a rough or industrial blower?
text 2011-07-16 09:28:53
08.05.2020 15:50 # 12
EmRe26
Hello everyone, good morning, I think about doing the application, I think it is going to sound from everywhere. As you said, when you used thermoflex, they obtained much more perfect results. This thermoflex material was a product used especially for sound insulation, the compressed spongy structure absorbs the sound and prevents it from entering, of course, it is an excellent application for vehicle insulation when used with bituself :) we are curiously waiting for the pictures. But where can we find this bitselfi? I guess it is in Thermoflex building materials. Is there a Bitüself coach or boat?
08.05.2020 15:50 # 13
F-Eren
There is also a bitüself bauhaus in a few different sizes in the costata. Call btm, access the number from the internet, and direct them to the nearest dealer. There are even kucukyali, you can learn by phone ...
08.05.2020 15:50 # 14
Haksen016
Kenan, I look forward to the stage of construction.
08.05.2020 15:50 # 15
friends finished 3 doors today 4. Material was not enough for the 4th door Wall I took the pictures in detail and I will add pictures at night.
respects
08.05.2020 15:50 # 16
metin
We eagerly await (:
08.05.2020 15:50 # 17
EmRe26
brother waiting pictures ...
08.05.2020 15:50 # 18
metin
It seems that you were going to install pugti in the evening. Ouch
08.05.2020 15:50 # 19
EmRe26
: D: D everyone is looking forward to the pictures
08.05.2020 15:50 # 20
Just like Kenan photos, put us in the light. I am thinking of implementing ..
Page : / 5
