door problem
08.05.2020 16:44 # 1
hhuzun
hi friends & nbsp; I had written the problem of the car before, there was a lock problem, how many I brought it to the garage, they couldn't find the reason, I lock the door, open the door automatically as if I had the door open, I lock the door with one hand locks; but there is no problem in automatic opening. I connected it to the computer, there is no problem with it. Pressing the button from the computer, pressing, pressing, all the doors are closing; and the computer says no errors;
& nbsp; & nbsp anyway; alarm system from buyil tr & nbsp; I say, I will cancel the reception center system; Do you think that when you get better, I would appreciate if your friends know how to help them? editID> 2012-04-30 12:21:13
08.05.2020 16:44 # 2
dukenukem82
Due to freezing in winter, my back left door lights up the ceiling lamp as if it is open from time to time. Then the alarm starts. I looked at the door, no problem. The patient will recover when he sees the doctor, or that account. It bothers me once in a while. One or both door locks seem to be troubling you.
08.05.2020 16:44 # 3
GO--GO
there was another issue with that .. anyway this problem is most likely caused by door sensors & nbsp; The sensor will be fixed when I change it, I have been living for a long time, I could not find any place I did not go, but eventually found a service. but the alarm system is not salvation, they said, waiting for my sensor to come to the service, the brain said it couldn't detect the sensors, the service was most likely, my sensor might have received water, they examined and found the right front door.
08.05.2020 16:44 # 4
hhuzun
Thanks guys, I just got back yesterday, there is no problem when I start the computer; he tightened the door lock to the finest, but there is nothing, he said maybe there might be a touch in one of the cables; said the same room, the alarm said no solution; my head is cartridges; There is no problem when opening but I lock all the doors with the inside and the main door at ten doors when locked
& nbsp; at first, to hold the left front doors from the inside, throwing them into the wheel; good luck everybody god bless you in your work
& nbsp;
08.05.2020 16:44 # 5
GO--GO
If your benefit has been touched, we are happy to contact us "Approve" God make it easier for all of us to work "Thumbs
08.05.2020 16:44 # 6
muratti
believe me, the only solution is the alarm that puts on afterwards. You will be comfortable when you take off
08.05.2020 16:44 # 7
mavituna
My remote door was not locked. All doors were closed. the problem was in the tailgate. There is a spring in the place where we press the hand and open the cover. he is broken. There he found and installed an electrician spring, and started to work. I wanted to give information.
