Door Lock Hk.
08.05.2020 20:12 # 1
whisky
First of all, hello everyone My name is Mehmet, age 28, Mersin,
My vehicle 2001 model 307 xt, all the doors are locked as soon as I close the car driver door I want to ask, so I did not try the deadlock event by holding down the lock button by looking at what I read in the forum, is there any other setting?
08.05.2020 20:12 # 2
dejawu1978
But is the button on the dashboard active ..?
08.05.2020 20:12 # 3
whisky
yes active. For example, when someone is getting on, the door locks are opened to pressure, but it locks itself in 3 seconds. so if the windows are closed when I get out of the car, I can't leave the key in the car. The driver locks the door when it is closed.
08.05.2020 20:12 # 4
OguzhanKucuk61
Normally I need to lock it after 10km / hi. If autolock is active. When the automatic lock is active, does the driver lock it when it closes its door? Or always?
08.05.2020 20:12 # 5
whisky
Even if I stop the car and close the driver's door, it is also working. There is no certain speed, so when it closes the door, the car locks, when it stops, in the evening, for example, when the door is closed, the headlights go out with the door in the headlight sensor.
08.05.2020 20:12 # 6
ggitaristt
If there is a continuous lock signal coming from the driver's door, it will be as you said. Possible reasons:
Lock sensor or adjustment is bad or sockets on the door are oxidized.
08.05.2020 20:12 # 7
whisky
Hmm, I have to take a look at that. If the key remains inside, he panic attacks on going home to chase the spare key: D
08.05.2020 20:12 # 8
KILIC
as if there is a short circuit at the door
08.05.2020 20:12 # 9
ben_erhan
Makes a room if the car is equipped with an alarm or later lock system. I also had the same problem. I had the alarm removed.
08.05.2020 20:12 # 10
whisky
There is no alarm in the car, but I will take a picture of it inside, there are 2 punches inside the front door that I don't know what is going on.
08.05.2020 20:12 # 11
JunioR56
The 2003 model has 1.6 xt. the lock button inside actively works. How can I auto-lock my question when I act? The car does not lock without pressing the button.
08.05.2020 20:12 # 12
BLACK LION
[QUOTE = JunioR56] 2003 model has 1.6 xt. the lock button inside actively works. How can I auto-lock my question when I act? The car doesn't lock without pressing the button. [/ QUOTE]
Press and hold that central lock button inside. A warning appears on the screen already, this is about the automatic locking is active. It now locks automatically after 20 km.
08.05.2020 20:12 # 13
BLACK LION
[QUOTE = whiskey] Friends first hello everyone My name is Mehmet age 28, Mersin,
I suggest you look at the settings related to how and at what time this lock will occur, such as the duration of the follow me home headlights from the trip computer screen. It is likely to be an option set at 3 seconds. If there is an electrical failure, it locks immediately. There seems to be an activated feature here.
08.05.2020 20:12 # 14
whisky
There is no follow me feature, I guess this model has not been tried at least a few times, and there are not as many options as you can see from the on-board computer, and there are no options to turn it into active or passive position. anti is also in trouble again. fault: D
08.05.2020 20:12 # 15
JunioR56
As far as I understand this process, we will do this when the contact is half open. My first job in the evening will be to try an automatic cam lock.
