door lock
08.05.2020 16:33 # 1
YUNNES37
Greetings again, I am with a problem.
I opened my 306's & nbsp; driver's door last night. ,
Since the weather was snowy and icy, I had to hang a little hard on the door handle. & nbsp; I opened the door.
then the door did not close.
the door does not close when the door is not closed, the five doors of the vehicle are still open.
08.05.2020 16:33 # 2
___KxL___
It is most likely frozen. Spray antifreeze glass to the place where the tongue of the lock is located or there are defrosters sold on the market.
08.05.2020 16:33 # 3
altantezcan
yes frozen synth thinner also dissolves but it does not know if it is problem or oil-free contact spray
08.05.2020 16:33 # 4
yavuz25
My free brother knows that job. "Wink"
08.05.2020 16:33 # 5
yavuz25
[QUOTE = altantezcan] yes frozen synthetical thinner also dissolves, but I don't know if there is a problem or oil-free contact spray [/ QUOTE]
thinner crippled work.
08.05.2020 16:33 # 6
yavuz25
Can we take a photo of the place where this door goes into the lock?
08.05.2020 16:33 # 7
06OzGuR06
[QUOTE = yavuz25] My free brother knows that job. "Wink" [/ QUOTE]
< br> "LOL" "LOL & nbsp; & nbsp; Reviews
08.05.2020 16:33 # 8
yavuz25
[QUOTE = 06EgGR06] [QUOTE = yavuz25] My free brother knows that job. "Wink" [/ QUOTE]
"LOL" & nbsp; & nbsp;
Didn't know or lie. "LOL" Joking aside my brother is a good master. "Wink"
08.05.2020 16:33 # 9
06OzGuR06
[QUOTE = yavuz25] [QUOTE = 06ÖZGÜR06] [QUOTE = yavuz25] My free brother knows that work. "Wink" [ / QUOTE]
I guess something was broken from the inside because the door handle was forced or it may be stretched. I think it should be dismantled. "Wink"
08.05.2020 16:33 # 10
yigiteroglu
I had the same thing in the trunk of my 206 cars. I think it's a temporary problem. My luggage did not close until I entered the closed garage due to the cold weather. I try to heat your car's environment, I guess the problem will be fixed. In addition, there are sprays in the building markets so that the vehicle door wick does not freeze. I work in customer service at Koçtaş Ankamall branch in Ankara. I will help if you come. :) If you share the result with us, I would be glad (z). :)
08.05.2020 16:33 # 11
sertacizm34
[QUOTE = yigiteroglu] I had the same thing in the trunk of my 206 cars. I think it's a temporary problem. My luggage did not close until I entered the closed garage due to the cold weather. I try to heat your car's environment, I guess the problem will be fixed. In addition, there are sprays in the building markets so that the vehicle door wick does not freeze. I work in customer service at Koçtaş Ankamall branch in Ankara. I will help if you come. :) If you share the result with us, I would be glad (z). :) [/ QUOTE]
Are these sprays harmful? I do not get much efficiency. It seems to me that it is doing worse, anti-fog, rain shifter etc. etc.
08.05.2020 16:33 # 12
yavuz25
I have never used these sprays but those who use it are satisfied. "Wink" We say that we take a photo of this lock, let's see the tongue slipped but I think it could not look at the subject . "Smile"
08.05.2020 16:33 # 13
sertacizm34
Yes. Photos are of great importance in expressing problems. Direct solution can be produced.
08.05.2020 16:33 # 14
yigiteroglu
Yes, the customers who use sprays say that it is beneficial, but as the valuable forum members stated, if you add a photo, we can identify the problem more easily. Perhaps it will require a little intervention to lubricate the language record or with a screwdriver. Clearer answers will appear if you put a picture. Apart from that, the problem caused by frost is that I recommend those sprays in the long term. The simplest app for now is try to heat it by holding a little lighter over the lock tongue of the door. If there is a frost, it will be solved and the door will close. If the problem is still not resolved, there is another problem. I did not pay attention to the door tongue there, if plastic parts are available, please hold the lighter carefully, if necessary, do not use the lighter to heat the freezing area.
08.05.2020 16:33 # 15
yavuz25
[QUOTE = yigiteroglu] Yes, customers who use sprays say that it is beneficial, but as the valuable forum members stated, if you add a photo, we can easily identify where the problem is caused. Perhaps it will require a little intervention to lubricate the language record or with a screwdriver. Clearer answers will appear if you put a picture. Apart from that, the problem caused by frost is that I recommend those sprays in the long term. The simplest app for now is try to heat it by holding a little lighter over the lock tongue of the door. If there is a frost, it will be solved and the door will close. If the problem is still not resolved, there is another problem. I did not pay any attention to the door tongue, if plastic parts are available, please hold the lighter carefully, if necessary, do not use the lighter to heat the floor [[QUOTE]
I think the tongue is covered with plastic.
08.05.2020 16:33 # 16
yavuz25
[QUOTE = yigiteroglu] Yes, customers who use sprays say that it is beneficial, but as the valuable forum members stated, if you add a photo, we can easily identify where the problem is caused. Perhaps it will require a little intervention to lubricate the language record or with a screwdriver. Clearer answers will appear if you put a picture. Apart from that, the problem caused by frost is that I recommend those sprays in the long term. The simplest app for now is try to heat it by holding a little lighter over the lock tongue of the door. If there is a frost, it will be solved and the door will close. If the problem is still not resolved, there is another problem. I did not pay any attention to the door tongue, if plastic parts are available, please hold the lighter carefully, if necessary, do not use the lighter to heat the floor [/ QUOTE]
"Clap" "Clap"
08.05.2020 16:33 # 17
Meric42
I've had the same event in the last sliding door that I had suffered and did not close. I use defroster. I squeezed all the ice melted. The door closed.
08.05.2020 16:33 # 18
YUNNES37
there is excessive snow on my street i am in a little high district of istanbul. & nbsp;
yesterday i tried to open the door. & nbsp; I did not come, the door was full of snow, frozen.
I also turned it off from the control & nbsp; closed. When the incident happened to me, it was not closing from the control and it was opening back.
is now closed. I have not been too tampered with.
let the weather get a little soft, the snow will melt again and if it doesn't close I will take a picture of the lock.
I will report the last situation.
08.05.2020 16:33 # 19
YUNNES37
Yes, friends, I did not feel cold in the evening, I went to extend the extension cable, and gave the car hot air at the door of the car with a hair dryer. 5 min. then the door improved.
