Door lock
15.02.2023 23:02 # 1
Sezer06
Selamun aleyküm friends, I have a 2011 patner hill
I have a car, when I crack the ignition, the central unlocking and closing system does not work at all after 10 minutes. the on/off buttons do not work, there is no problem with the ignition, the battery or something has changed, I would appreciate it if you could help me.
16.02.2023 14:55 # 2
talip206
The ecu of the vehicle is its brain. It goes into sleep mode after a certain time after stopping. (Excluding the lock receiver)
If there is a subsequent intervention, the cable may be drawn from the wrong line to the locks.
16.02.2023 17:04 # 3
Sezer06
In fact, the car had broken the wires into the iron and gnawed it, I had it done by the master, but this central lock problem existed before that, so there was no intervention, I always changed the fuses, still it did not improve, there is an immolayzer question, they said, let the Imolayzer read the ignition, I did it as they described, it still did not work after a while, he forgets the plug. I will be glad if you guide me
17.02.2023 17:15 # 4
talip206
Friends who know where you live will guide you.
18.02.2023 08:44 # 5
Sezer06
Ankara
27.08.2025 00:50 # 6
Sabri45
Hello, did you find a solution to the problem? I have the same problem and I can't find a solution.
04.09.2025 19:32 # 7
brs3393brs
The problem most likely isn't with the remote control; the BCM (central locking computer) is entering sleep mode. Check the battery voltage; if it's low, it will generate this error. If the problem persists, you may need to update or reset the BCM software.
