Door lights
08.05.2020 16:42 # 1
MuratUlg
I am using 2005 peugeot 3007 1.4 hdi normally the ceiling lamps that should be lit when opening doors or locks do not light up but when they close the door after opening them with normal hands, what could be the reason? I do not know if the subject has been opened before. Thanks in advance
08.05.2020 16:42 # 2
teoman_40
I have the same problem, I would be glad if you could help my friends. Here the electrician looked, did not understand something ...
08.05.2020 16:42 # 3
Usually such problems can be resolved by long pressing the button (about 10 seconds). If you want, give it a try and share the results. koliva 2012-04-17 19:37:02
08.05.2020 16:42 # 4
[QUOTE = koliva] Usually, these kinds of problems can be resolved by long pressing the button (about 10 seconds). If you want, give it a try and share the results. [/ QUOTE]
& nbsp; As the manager says, long press on the interior lighting button will be activated.
08.05.2020 16:42 # 5
MuratUlg
Yes, finally, I removed the ceiling light for this or something :) I would draw a led light inside the vehicle, I scratched it
08.05.2020 16:42 # 6
teoman_40
Thank you very much Koliva. I just took care of the problem as you said. Let those who have problems try :)
08.05.2020 16:42 # 7
teoman_40
When the friends open the door, the lights are on but when they close, the lights do not go out by themselves. It turns off when I turn the ignition inside and lock the car if I am outside. Wouldn't it be any other way, so what should I do to get out by itself when I close the doors?
08.05.2020 16:42 # 8
[QUOTE = teoman_40] Koliva thank you very much. I just took care of the problem as you said. Let them try the problem:) [/ QUOTE]
You're welcome.
[QUOTE = teoman_40] When I open the door, the lights are on, but when they close, the lights don't go out by themselves. It turns off when I turn the ignition inside and lock the car if I am outside. Wouldn't it be any other way, so what should I do to make it go off by itself when I close the doors? [/ QUOTE]
Just need to wait "LOL" Soner spontaneously after a while.
koliva 2012-04-18 12:14:00
08.05.2020 16:42 # 9
teoman_40
Just like that, I waited a little bit, I think "Clap"
