door lighting
Homepage » PEUGEOT MODIFIED PLATFORM » 307
08.05.2020 17:26 # 1
mhakan71
I want to make a peugeot 307 under-the-door lighting, first of all I need to get the electricity from the front and rear doors, which product I will use for lighting http://www.sanel.com.tr/sbb.html I'm waiting for your help ...
08.05.2020 17:26 # 2
Alicilik
[QUOTE = mhakan71] I want to make a Peugeot 307 under-door lighting, first of all I need to get electricity from the front and back doors, I need your product & nbsp; http: //www.sanel.com.tr/sbb.html I'm waiting for your help ... [/ QUOTE ]
How do you want the lighting to work?
If you want to work with the door, you will have to pull the cable from the ceiling lamp.
If you say no, work with the parks, if the glass button has illumination, you can get current from it and the leds do not draw much current. < br>
08.05.2020 17:26 # 3
serkan719
I plan to do it when I remove the door trims.
If it fits Mercedes, I will use it as lighting.
but instead of removing the ceiling lamp, you should look for the cable that goes to the ceiling. Anyway, the room goes from below.
08.05.2020 17:26 # 4
blinddark
What is this price of my teacher
08.05.2020 17:26 # 5
mhakan71
[QUOTE = blinddark] what is my teacher price [/ QUOTE]
sanel leds 14 tl
08.05.2020 17:26 # 6
mhakan71
if we squeeze the electricity out of the ceiling lamp, it will be lit on other doors when a door is opened, but I just want the door to be lit so it feels like we need to find the sensor cable inside the door
08.05.2020 17:26 # 7
serkan719
It is necessary to put a swich there as there are swich places inside the doors.
08.05.2020 17:26 # 8
NightKiss
Would you share the pictures, please?
08.05.2020 17:26 # 9
serkan719
of course I share.
08.05.2020 17:26 # 10
coolhortlak_307
Sir, I did the application you said, I removed the back doors, cut them and took them from the trunk lighting lamps. How do I find it or have it in all vehicles 2005 307xt
08.05.2020 17:26 # 11
coolhortlak_307
I would recommend 6.5 TL on the site for luggage lighting.
