Door Hardening Problem
08.05.2020 20:09 # 1
Baran35
Hello guys, I didn't have the first time I bought my car, but later on the back doors got stiff. Namely, when I open the door, when I close it, there is a sound like a plug. And when I push and release it to close, it stops. I don't know if it is necessary to squeeze or drive anything to the hinges. There is no problem in the door lock, when it closes, it closes easily. I would be glad if there are friends who can help ..
08.05.2020 20:09 # 2
h.can
I do not think it will be related to the hinge, as it is related to the door lock and its equivalent. the H. C. 2017-01-31 13:24:23
08.05.2020 20:09 # 3
onlycihan
I guess your door pins need to be changed, I think they usually hold the door tensioner, if they have a problem, they both gradually make a sound, and the tensioner cannot pull the door completely and close itself.
08.05.2020 20:09 # 4
pepecura
the mechanism that deflects the classic pejo door in mild and cold weather like you call back doors in me :)
08.05.2020 20:09 # 5
KILIC
check the door tensioners may be loose. If the screws are not, you need to replace them. It was priced like 30-40 TL.
08.05.2020 20:09 # 6
pusutr
I have the exact problem, and the solution is to change this part. here is the classic pejo.
http://urun.n11.com/oem-yedek-parca/peugeot-206-arka-kapi-gergisi-p120118105?cid=604001&gclid=cjwkeaiaq8bebrduuouyspf5oymsjaacseywzqwysmmxaıpoc6b2jbcıpjsahpkormkzj6ffhosqnhocmaxw_wcb&gclsrc=aw.ds
08.05.2020 20:09 # 7
Baran35
Thank you all for your valuable comments. This weekend, the way of the body shop seemed like that :) May Allah not give you any trouble.
