door handle scratch removal
08.05.2020 17:31 # 1
ulas81
The first message I posted to this forum .. I hope I was able to upload the picture .. 2 months ago I bought a 2004 307 sw .. luckily it was a vehicle that was used very cleanly, it was not worn down but there were wear and tear marks on the door handles. both sides (we couldn't think of photographing the state before removal)
then we sanded it with water sander ..
then we painted a beautiful with acrylic matte black
and the result
< br>
08.05.2020 17:31 # 2
Gokhan Cetin
you have to try very well
08.05.2020 17:31 # 3
leffe
The white door icon on that key is not affected by the paint
08.05.2020 17:31 # 4
cerci07
it is clean at first but if it gets paint over time, it looks bad and still good work
08.05.2020 17:31 # 5
theyet
thanks for your effort
08.05.2020 17:31 # 6
Gokhan Cetin
If you pay attention to Leffe, the key stays on.
08.05.2020 17:31 # 7
samet206
Good job sometimes relieves such details. I hope your paint will be durable.
08.05.2020 17:31 # 8
ulas81
[QUOTE = leffe] Is the white door icon on that key not affected by the paint [/ QUOTE]
sql98, as the friend says, the glass opening controls are removed with their nails ..
& nbsp;
[QUOTE = onurazgin] those paints will unfortunately grasp: / the better solution I have made will wait for the cellulosic thinner then the soft layer will peel off and there will be a paint job like zero. . [/ QUOTE]
& nbsp;
is already scrapped first .. As you scratch it, the soft layer you say is like a gum first, then it throws itself ... we were hesitant about making synthetic or acrylic alone. .. we made acrylic with the advice of the painters .. if we experience anything negative, I will try the bidet with synthetic ..
08.05.2020 17:31 # 9
ulas81
[QUOTE = 307bursa] good health for your work I have done this job many times before, in most of the time, the paint started to peel over time, I finally found the solution for about 8 months, it looks the same way & nbsp;
the operations you have done are more solid if you apply spray varnish on top is happening and does not easily peel off etc. & nbsp;
yes they said you said this .. / div>
08.05.2020 17:31 # 10
CHK35
Good information
08.05.2020 17:31 # 11
SDYMZ
wow it was very good
