|   | Door Handle Painting |
| • Homepage » PEUGEOT MODIFIED PLATFORM » Modification and Tuning Information | |
| 08.05.2020 16:47 | # 1 |
|  TeknolojiDelisi | |
|  other arm then divide   then this way I prepared a layout and started painting beautifully & nbsp;   fell inside me and I will continue to innovate ....  | |
| 08.05.2020 16:47 | # 2 |
|  koliva | |
It looks very successful. Did you use sandpaper + primer + paint?
| 08.05.2020 16:47 | # 3 |
|  TeknolojiDelisi | |
yes, I did not use zero number sanding primer, I applied 3 layers of paint and in this case & nbsp;
| 08.05.2020 16:47 | # 4 |
|  ufuk91 | |
what was the paint you used?  by the way, congratulations you did a good job | |
| 08.05.2020 16:47 | # 5 |
|  TeknolojiDelisi | |
| 08.05.2020 16:47 | # 6 |
|  Alicilik | |
It has been a nice work but if you have not sanded and cleaned with thinner it will be 2-3 months old. & Nbsp;
| 08.05.2020 16:47 | # 7 |
|  TeknolojiDelisi | |
Well, I cleaned all kinds of paint and spray paint.
| 08.05.2020 16:47 | # 8 |
|  Alicilik | |
I tried so much, so I said. First you need to make a fine sandpaper and then clean it with thinner. After that, when you draw the paint, believe it is legend. It would be nice if you would like to put a very gentle matte finish on it.
| 08.05.2020 16:47 | # 9 |
|  TeknolojiDelisi | |
[QUOTE = ScHerZo] I tried a lot so I said. First you need to make a fine sandpaper and then clean it with thinner. After that, when you draw the paint, believe it is legend. It would be nice if you would like to put a very gentle matte finish on it. [/ QUOTE]   okay, when I delete it, I will make this shape, I wrote this in mind & nbsp;  | |
