Door handle
Homepage » PEUGEOT MODIFIED PLATFORM » How To
08.05.2020 16:18 # 1
My left back door has been opening very hard for 3 days. I bought it from outside yesterday. The room opens the door, but I don't know how it has been pushed enough?
2; While trying to reach the lock, the white foamy body used for this insulation was deformed from place to place. Then I got angry with a suitable sentence. no, can i find the same or can i find something suitable for this job i think sound isolation affects many
Uploaded with ImageShack.us
3; I guess some of these clips have been broken, and I think those who do things that can be worn out are broken. Where can I find new ones?
08.05.2020 16:18 # 2
metin
There are as many as you do not want murat monument from white clip. When I intended to insulate the last door, I bought a few more to break the floor while opening it.
08.05.2020 16:18 # 3
Murat is away with his brother right now, but it is not worth paying a little bit of cargo. Is there any spare particle?
08.05.2020 16:18 # 4
metin
[QUOTE = HuseyinTurk] Murat is far away with his brother right now, but it is not worth it to ship. I found it there when I called. It is necessary to investigate whether it is outside.
08.05.2020 16:18 # 5
I guess you can find it if you ask the parts around for a "door trim clip". In addition, they were probably broken when you sting those who were broken.
& nbsp;
If you had the door door isolation closed in place to tear the same place it was tearing off ...
CeCoLi 2011-10- 27 15:48:58
08.05.2020 16:18 # 6
I had to tear off the isolation, I said that the piece should not be pinch to reach the brother, I did not tear it completely, then I did not hold it, instead of throwing it in me, it was as if the insulation was the number ten, then & nbsp; "Grin"
08.05.2020 16:18 # 7
[QUOTE = HuseyinTurk] I had to tear the isolation, I thought the piece should not be pinch to reach the brother. border = "0" alt = "Grin" title = "Grin" /> [/ QUOTE]
keep warm :)
08.05.2020 16:18 # 8
mdincer34
there is a slikon-like adhesive that attaches that isolation to the door, you could remove it from it, but there is a material that is used in sound insulation from torn, I get the flooring material from it, I also cut the silicone and made it to 4 doors, I recommend it.
