don't stop
17.02.2022 22:40 # 1
hakangnr16
Hello friends, rarely, while waiting at the traffic lights, the vehicle stops, please help.
19.02.2022 14:43 # 2
GokhaN
Can you check idle while you wait?
21.02.2022 10:42 # 3
is there lpg in the car
28.03.2022 19:57 # 4
hakangnr16
There is no fluctuation at idle, the vehicle with LPG stops suddenly, as if you turned off the ignition, the bidet does not eat gas from time to time, even if I press the pedal all the way, there is no one. After a couple of pumps, the idle sensor has just changed. The problem continues
30.03.2022 18:46 # 5
x571
Sir, the best is to remove the fuse of the LPG. Let's see for a day or two. If it's not a problem, you can take it to lpgciye and explain the problem. You can connect it to the computer, maybe it needs to be adjusted, it's a simple thing.
30.03.2022 22:13 # 6
hakangnr16
I'm guessing it's not related to LPG, because it's the same in gasoline, even when it slows down, it stops more and more, sometimes I wonder if the throttle body adaptation is necessary because the butterfly was cleaned before but the adaptation was not done, I guess it could be because of it??????
01.04.2022 17:38 # 7
hakangnr16
We connected the car to the pc, it gave an oxygen sensor failure. I changed the sensor, but it still stops, it does not give any other malfunction, please help....
09.04.2022 11:39 # 8
Emrah2112
I had the same problem, I cleaned the throttle and it passed.
09.04.2022 12:11 # 9
hakangnr16
My problem started after the throttle was cleaned, I changed the idle valve, the oxygen sensor also changed, but the result did not change. After your cleaning, was there an adaptation or something to the throttle?
09.04.2022 14:11 # 10
Emrah2112
No adjustments were made to my vehicle.
09.04.2022 14:12 # 11
hakangnr16
I guess the last resort would be to replace the throttle, thank you
10.04.2022 20:30 # 12
ulas55
hello bro, i had this problem years ago in my polo classic 1.6 lpg vehicle, it was stopping in both gas and gas, whatever we did, the throttle problem was the last, the master had done something, he cleaned it well, he adapted it and it worked fine for a long time. When the same problems occurred again, I took the vehicle to the authorized gas service in Istanbul, they almost completely renewed the installation of the LPG system of the vehicle, they changed the bidet regulator, then the car became like a clock, then I sold it that way, the friend who bought it did not have any problems after me, but these things I told 10 years ago are really annoying. it was the topic. take it easy.WinkWink
