don't you answer my question
08.05.2020 15:47 # 1
vefa3336
307 sw power steering hum
08.05.2020 15:47 # 2
berk2309
I have a normal voice in our 307s vınlıyo constantly wear your head
08.05.2020 15:47 # 3
vefa3336
Is it normal, believe me sometimes I get scabies that sound, especially in the evenings as if coming more
08.05.2020 15:47 # 4
berk2309
Occasionally there is too much in me, then it gets better, sometimes it is hard, sometimes it is very soft according to the head: D that whistling sound usually you will hear in most of the 307s.
08.05.2020 15:47 # 5
vefa3336
thank you thank you I'm a little relieved. Also, how many thousand of trigel belts change my vehicle more than 57000
08.05.2020 15:47 # 6
berk2309
You can change it in 80 thousand maintenance or you can say 5 years but I think you can change it in 60 thousand times it won't hurt. I advise you to use the original set and original circulation while changing
08.05.2020 15:47 # 7
vefa3336
ok thanks, i am from erzincan i dont have service here. but I will replace it with the original everything
08.05.2020 15:47 # 8
berk2309
I ask you to play originally, good night
08.05.2020 15:47 # 9
iibrahimm
it sounds like it is not so disturbing but when i push the steering wheel to the end, there is a very different sounding but there is no harm in it other than sound
08.05.2020 15:47 # 10
Otuken
It is normal to sound when the steering wheel stops. the sound of the belt. the pulley stops, the belt slips.
08.05.2020 15:48 # 11
[QUOTE = Otuken] It is normal to hear sound when the steering wheel stops. the sound of the belt. pulley stops, belt slips. [/ QUOTE]
The Peugeot 307s have an electric steering pump.
